warpspd's Avatar
Send a message via ICQ to warpspd
76 carrera 3.0
I just purchased a 76 3.0 carrera a few weeks ago. I just wanted
to get some info on this car. I checked in bruce anderson's performance handbook on the authenticity of the vin number which is 9116600251. The engine number is 930/02 which is
the correct 3.0 litre. This car does not have a vin plate on
the front window post. I wondered where I could get one
stamped with correct vin on it to maintain the originality
of the car.
I traded my motorcycle for this car so I am really not sure
of the true value of the car.I was told by several sources
that the value is comparable to the 78-79 911SC is this
true?
How much would updating the car to newer body and
interior pieces hurt the value. Since this car is sort of a
special model I am thinking that it should be kept as
close to original as possible.
sorry for such a long post.. thanks in advance...
Old 12-07-2003, 11:32 AM
See here:
Show me your original Carrera 3.0!
Old 12-07-2003, 11:56 AM
The Carrera 3.0 is MORE interesting than a '78-'83 SC. Lighter, livelier (thanks to the 2.7 crank), and more exclusive (3600 built in all).
here 9116600362:
Old 12-07-2003, 12:04 PM
drag racing the short bus
dd74's Avatar
The '76-'77 Carrera is coveted on this board - at least I off-and-on covet one. I don't think you'll garner much support to "update" the body. You can lighten it by removing things like the rear seat, getting rid of the electrical equipment (windows and sunroof, etc) and changing to a lightweight battery.
It'll supposedly give an SC a tough time (read: outperform) in most cases.
I'd leave it as is.
The Terror of Tiny Town
Old 12-07-2003, 12:27 PM
autoxracer31's Avatar
Send a message via AIM to autoxracer31
hey guys: this might be too off topic but, I have a 1974 that I put a 3.0 liter in... Is it lighter/ faster than an SC too???
Old 12-07-2003, 12:55 PM
dd74's Avatar
I've done the same - '74 with a 3.0. Yes, it's much lighter than an SC, and lighter than a Carrera 3.0, though this might be disputed in some circles.
Reasons:
1) No power equipment
2) No galvanizing
3) Although the 3.0 is heavier by about twenty pounds than the 2.7, the '74 still utilizes the magnesium gearbox.
4) Lighter (smaller diameter actually) wheels and (I believe) lighter brakes.
What year is your 3.0 liter?
Old 12-07-2003, 01:12 PM
the engine i had put in mine was a 78' along w/ removing the sportomatic tranny i put in a 915 5speed from 82? 83? one of the 2 years
Old 12-07-2003, 01:14 PM
Send a message via AIM to fintstone
Should be significantly faster if sorted out properly.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 12-07-2003, 01:15 PM
since you have done this w/ a 74' , i need to upgrade my brakes but i only have 15 inch fuchs, any suggestions
DD, the '76 still used a magnesium gearbox, actually, some '77 did as well.
Old 12-07-2003, 01:16 PM
dd74's Avatar
Did it? Very interesting. That might explain use of the 2.7 crank as well - left over pieces from previous model years, etc.
Autoxracer31: On a '74, I'd stick with 15-inchers, but use wider 7-inch wheels. The widest tire you can safely fit with that wheel is a 205 width, 60 series tire. 55-series might be nicer. 50s are best, but you'll need to lower the car to avoid the large wheel-well gap between the tires and fenders.
Old 12-07-2003, 01:28 PM
dd74's Avatar
Again, I was comparing weight between Autoxracer31's '74 3.0 and a standard SC. I'm still fuzzy on the stats concerning the Carrera 3.0, though I'm learning...
Old 12-07-2003, 01:32 PM
Autoxracer31
If you have the "S type brakes".......alloy front calipers......then they are pretty darn good for most applications. (If not...there seem to be a lot more for sale lately. I am afraid you probably gave up some acceleration with the higher geared newer tranny though. I agree with dd74....keep the 15s or you will loose a bit of acceleration.
Old 12-07-2003, 02:15 PM
