-   -   RSR Distributor (http://forums.pelicanparts.com/porsche-911-technical-forum/138147-rsr-distributor.html)
126coupe 12-03-2003 08:30 AM
RSR Distributor
My 3.3 turbo engine is a twin plug. How do I know if the distributor is RSR? and if its not what else could it be? Praying its RSR
Tim Walsh 12-03-2003 08:34 AM
If it's RSR then you will have a massive distributor. It will have 14 leads going to and from it (2 coil and 12 plug). The other popular options are the 964 which is 2 normal looking caps side by side. You could also have direct ignition which would be 12 leads that plug into coil packs basicly it's a big block with 2 leads plugging into each of the 6 sections.
126coupe 12-03-2003 08:38 AM
Have not got the car home too pull intercooler, but its not side by side, looks pretty massive!
Tim Walsh 12-03-2003 08:55 AM
sounds like you've got an RSR dizzy. Congrads. I'll bet that car runs like stink.
emcon5 12-03-2003 09:30 AM
The 964 type looks like this:
http://forums.pelicanparts.com/uploa...1069134785.jpg
RSR looks like this:
http://forums.pelicanparts.com/uploads/pp3.jpg
The 964 type won't work on a turbo. It won't fit with the turbo plumbing, so if you have a distributor, (and not some sort of crank-fired ignition) it is likely an RSR.
Tom
