RSR Distributor
My 3.3 turbo engine is a twin plug. How do I know if the distributor is RSR? and if its not what else could it be? Praying its RSR
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
If it's RSR then you will have a massive distributor. It will have 14 leads going to and from it (2 coil and 12 plug). The other popular options are the 964 which is 2 normal looking caps side by side. You could also have direct ignition which would be 12 leads that plug into coil packs basicly it's a big block with 2 leads plugging into each of the 6 sections.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Have not got the car home too pull intercooler, but its not side by side, looks pretty massive!
sounds like you've got an RSR dizzy. Congrads. I'll bet that car runs like stink.
Hilbilly Deluxe
The 964 type looks like this:
![]() RSR looks like this: The 964 type won't work on a turbo. It won't fit with the turbo plumbing, so if you have a distributor, (and not some sort of crank-fired ignition) it is likely an RSR. Tom |
