Question '67 911S Charging Problem - Help Neede
Hi folks. I'm sorry if this is a long 'setup' to my question, but
I'd rather provide too much information than too little.
I recently purchased a '67S sunroof coupe beautifully restored
to 'as original' condition. After being driven about 50-100
miles the first afternoon of it's arrival it wouldn't crank. A
quick recharge with my 10 amp manual charger got it going
again, but that night I noticed the red alternator light glowing
dimly all the time (something I hadn't seen earlier that sunny
day). The connector was found to be partially disconnected
from the voltage regulator (probably due to vibration during
the 1000 mile truck ride??) so I pushed it all the way 'in'.
Now the alternator light is only on when it "should" be.....i.e.
if the engine cranks, but doesn't start, etc.
However the alternator is still not charging the battery. My
old analog volt / ohmmeter shows the voltage across the
battery remains the same (about 12v) with the engine running
at or above idle as it is with the engine stopped. (It does show the normal drop in voltage when the starter is engaged during cranking.) Every week or so, I remove the battery for charging.....it charges at the max 10 amp charger rate for an hour or so before the rate slowly drops.
The alternator was rebuilt during restoration and has been
rechecked and found ok by the shop that did it. A new
voltage regulator was plugged in without any affect on the
battery voltage while running. During removal, I checked that
the alternator wiring was correct according to the L59 911S
wiring diagram in volume II of the factory manual. The fan
belt tension seemed ok to me. Continuity of the alternator
and regulator ground wires is good, and the continuity of the
two wires running between the alternator and regulator is
good.
After studying the wiring diagram more, it appeared to me
that battery voltage should reach the alternator thru the red /
white striped wire. After removing the battery, I checked but
did not find any continuity between the red / white striped
wire alternator terminal and the positive battery terminal.
Investigating this further, I find that the smaller positive
(black) wiring coming off the starter soleniod terminates at
what appears to be a junction block mounted below the
ignition coil, but goes no further. This "junction block" is
shown in L59 between the #3 voltage regulator and the #8
Resistor, but is not labeled. The junction block has two
"sides" or posts, with two wires coming together on one and
just the single black wire from the starter solenoid on the
other. There is no electrical connection or continuity
between the 2 sides.
Looking at the SL 33 wiring diagram for 911E, 911S shows
what appears to be a similar connection at a #60 "terminal
bar".
This brings me to my questions:
1. Is the "junction block" as I call it really a junction
block?
2. Should all three wires make electrical connection
here?
3. If so, how is this accomplished as from the factory?
Is there a jumper wire or a strap between the 2 sides?
A definitive answer on this would be warmly appreciated....
Best Regards,
Bob S.
Bob Schaefer
Old 12-05-2003, 06:30 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
I wish I had a definitive answer for you but I'm not that much of a electrical guru especially the pre70 cars (no 14 pin connector and lots of other things). BUT welcome to the board and you've got a really great car from the sound of it.
Also welcome to the NC area, sometimes it feels like the SoCal of the east coast theres so many 911's. I'd love to see your car on the next Fun Run.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 12-05-2003, 06:38 AM
Send a message via AIM to fintstone
Bob
Just another shadetree mechanic, but it appears the red/white wire is your B+ which must go back to your battery for charging. Yes the 3 wires should be connected at the junction block. The B+ wire should go to the battery from the junction block via a black wire to the starter hot lead...not solenoid..and then to the battery via the starter cable. Along with the black wire, another red/white wire should also be attached to the starter side of the junction (same place as the black wire) that goes to pin 30 of your fuel pump relay. Sorry, I don't have an early model to tell you how the junction is normally made bridged.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 12-05-2003, 08:26 AM
I'll check for you when I get home. If I remember correctly I have all 3 wires on the same post.
Doug '67 911 2.2
Old 12-05-2003, 09:56 AM
I checked, 3 wires all go to the same post. The other is empty. 2 black wires, one large red. One black one goes to the old resister assy, the other I believe to the starter.
Doug '67 911 2.2
Old 12-05-2003, 04:57 PM
