-   -   Motor Migration - Vision Test (http://forums.pelicanparts.com/porsche-911-technical-forum/138520-motor-migration-vision-test.html)
DonDavis 12-07-2003 11:24 AM
The back seat was sacrificed as well. Not that it was going to be used AT ALL in this car. When I rode in it I was really impressed with how comfortable the ride was. While taking hard corners, I did not feel as if I were being flung about. That had a LOT to do with the seats, too.
Zeke 12-07-2003 11:26 AM
Jack, put some rosebush clippings on a piece of corragated cardborad and lay that on top your car. Rosebush clippings work wonders in flower beds to keep cats out.
Tyson Schmidt 12-07-2003 11:40 AM
Originally posted by scca_ita
I now have coilovers. What would the weight savings be for just removing the torsion bar anchors? Any pictures of this and how to re enforce once they are removed?
I remember it being about 4 pounds. (But how much I added back with reinforcements??????)
I took a lot of pictures with Dave's (TRE owner) digital camera, but I'm not sure what happened to those pic's. Maybe he deleted them for secrecy?????
Jack may still have the pictures he took while I was doing it, but those don't show the process or the detail.
I cut open the rear seat area to gain access for reinforcement when I tied the center tunnel in with the front of the torque tube. And due to the significant space required by the Smart racing inner camber boxes, it made sense to just remove the whole rear seat area since the roll cage made the jumpseats useless anyway.
MoreGAS 12-07-2003 12:12 PM
BB1 was around 37/63.
Despite using the same drivetrain, and now having f-glass doors and fenders, the weight distr. on BB2 is now 39.5/60.5
Moving the drivetrain forward also puts more of it within the wheelbase, so the front wheels share more of the load, and don't lose as much grip from weight transfer.
Evil
I would be interested to see these corner weights and #'s. Maybe your total wt is high??? This does not reflect what we see when we set up these 911's for the track due to the fact that the engine and Gbx represent such a large portion of the total weight, and ther are perched so far rearward of the rear axle, atleast on a light say 2000-23000 lb race car, that one cannot improve the frt rear percentage that great. Maybe 63/37 is the best we ever see with a bunch200-300lbs) of lead doing the ballasting up to class weight. Unless, the car is say 2700 lb ish, and full gas say 22 gallons at 6.2 lbs per gallon way forward. The heavier the car becomes and the more petro, the smaller the % of the total wt the engine/gbx represents. Fiddle with the numbers alittle by adding weight forward in 50 lbs increments to one end vs the other and you'll see not much happens %-wise.
Kevin Roush
GAS Motorsport
Performance Porsche
_________________
"Evil
Tyson Schmidt 12-07-2003 12:47 PM
Well, he has an underbelly condensor, A/C evaporator, dual oil coolers up front, front condensor, fire-safe bottle up front, full cage, and we took a lot of weight out of the back compared to the old car as well. Lexan rear window, 911R taillights, fiberglass quarters, 72 oil tank location versus '73. I'm sure there are other factors.
It showed 2389 on the corner scales (with no driver), and that was with 1/2 tank of gas. The F/R distribution figure is with me in the driver's seat. (#175)
Jack Olsen 12-07-2003 01:25 PM
I now have coilovers. What would the weight savings be for just removing the torsion bar anchors? Any pictures of this and how to reinforce once they are removed?
I don't know about the weight savings, but the weight of the torsion bar anchor is kind of wasted when you're not using torsion bars. I think the total weight change could have been a wash, with the reinforcements, but the benefits are clear -- engine forward about an inch, and diagonal reinforcements imroving rigidity. Here are some pictures:
http://forums.pelicanparts.com/uploa...ndWhistles.jpg
http://forums.pelicanparts.com/uploa...orcement02.jpg
http://forums.pelicanparts.com/uploa...orcement01.jpg
http://forums.pelicanparts.com/uploads/99RearSeat.jpg
Tyson Schmidt 12-07-2003 02:54 PM
It's actually closer to 1 1/2". There's room for more movement as well, with some more tweaks to the trans cross member. But why get greedy.
Axle life has been fine. Still feel great after a lot of serious track work.
Shuie 12-07-2003 04:20 PM
Tyson, great job on this car!
Since the backseat sheetmetal has been replaced, what did you hook the tranny mounts to? Also, is the replacement panel in the backseat area welded, screwed, or riveted in place? Is there a significant benefit or risk of welding diagonal supports to the tortion tube in a car that is not going to use a coil over suspension?
Thanks!
Tyson Schmidt 12-07-2003 04:52 PM
Thanks!
Thank you!
The trans. actually mounts to the torque tube, so no issue there.
The only thing I had to work around were the tabs for the brake hoses. They normally attach on the bottom side of the the rear seat tubs. I welded tabs off of the control arm pick-up points instead.
Any bracing is going to help, but I don't think it's necessary if the torque tube is still completely intact. Especially if you aren't tracking the car with huge slicks, or have lots of HP.
scca_ita 12-07-2003 05:16 PM
Wow, I guess that is a little beyond my skills. Are these the type of mods needed for a G50 tans install too?
Shuie 12-07-2003 05:27 PM
Thanks for the help. I had to go back outside and look at my engine and trans on the dolly, but I see what you are saying. Dumb question, sorry about that :)
Tyson Schmidt 12-07-2003 05:29 PM
You don't have to do this to fit a G50, but if you don't, it puts the engine back in the chassis nearly an inch. Not exactly a good trade-off just for a little better shifting, especially since the G50 is so damn heavy to begin with.
Jeff Alton 12-07-2003 06:35 PM
Tyson, wow it sounds so easy I think that I might just head out to the garage right now!!!! Just kidding! I recently read about the work in Excellence and it sounds truly amazing. Nice job.
Jeff
MoreGAS 12-07-2003 10:20 PM
The numbers then are(roughly) 775# across the back, and 506 #across the front, with you in the car(175#) at a total weight of 2564 with 1/2 tank of gas? I will check my notebook manana but from memory I have serious doubts whether this is possible and have had many discussions about it with the rulemakers in the POC regarding older cars putting in later motors and updating to later specs and total weight , but having a percieved weight distribution advantage. I have notes on atleast 10 cars in this weight range.
Bottom line is the weight comes very easilly off the frt of the car but the rear is a fixed quantity, even moving the engine as you did you only gained about 45lbs of weight distribution change(assuming the gents math was correct regarding the polar moment-which feels correct from previous calculations I have done).
I have added 300 lbs of lead to cars forward of the frt seats in a 2450# car and cannot get where you claim to be on a 2564 lb car? Those little factors like lexan, taillights, light rear bumpers, are a given on most of the track cars. The oil tank movement is a help though.
Kevin Roush
GAS Motorsport
Performance Porsche
"Evil" Gruppe member #001
Tyson Schmidt 12-07-2003 11:07 PM
I'm going from memory on this Kevin, so I may be remembering it incorrectly. I'll try and find the sheet. It was done at Marty Mehterian's shop on his scales. (Maybe they aren't that accurate???) And it was about a year ago, so maybe my memory isn't what it used to be.
Jack's car still uses a magnesium trans. also, FWIW.
We just recieved our new scales and platforms at TRE, so I'll be rechecking it soon enough anyway. I'll let you know what it comes out to.
Randy Webb 12-07-2003 11:09 PM
Do you mean the trans is an early 901?
What did you do to hook up the CV joints to the trans?
speeder 12-07-2003 11:40 PM
Randy, 915 trans were magnesium up until '75(?). :cool:
Jack Olsen 12-08-2003 12:10 AM
1977 was the last year of the mag-case 915, I think. Mine is a 77, although it also has the billet side plate and a heavy cooling pump and cooler just ahead of the rear axle.
k9handler 12-08-2003 12:22 AM
QUOTE:
The rear engine crossmount just needed to be bent back straight, since it was modified to fit the 3.6 into an early car, so I just put it back to where it was, and reinforced it.
I have a question, as I don't think mine was changed at all...so is it different in a middle year car?
Tyson Schmidt 12-08-2003 09:17 AM
No, they are all the same. I would bet that they just didn't worry about it. The rear mount will flex forward and backward quite a bit. It is designed to be very stiff in relation to the engine twisting, but allows a lot of fore-aft movement. The trans mount takes care of the fore-aft movement.
