Licensed User
Shuie's Avatar
Backseat sheetmetal replacement
I have cut my backseat out due to rust. The replacement panels for this area of the car are not currently being made by anyone and finding a donor for this section is not likely in this area.
The panels I have cut and fit are 18-20 gauge galvanized. I hesitant to weld this stuff becuase I think this area is too confined to be burning galvanized metal in. I can pull them out of the car and weld them at the seams, no problem. I just dont want be breathing the fumes from this stuff in the confines of the car.
Would it be a bad idea to rivet these panels in place instead of welding them?
I know this area is supposed to be non structural. The rivets would be easy to drill out in the future when/if the replacement panels are available. The whole area is also going to be covered in carpet.
Old 12-08-2003, 09:02 AM
Friend of Warren
How about just using a fan to blow the fumes out of the car. I imagine any box fan would solve that problem.
Kurt V
Old 12-08-2003, 09:04 AM
DavidI's Avatar
I had mine welded in place. The welder used a fan and had no problem. He fabricated it out of galvanized steel (18 guage). Good luck, David
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 12-08-2003, 09:11 AM
sammygon1's Avatar
Careful your fan isn't too strong you don't want to blow away your gas shielding while you weld. Assuming you going to use a mig of course. Good luck, Sam
Sam Gonzales
'69 912 2.0 -6 power
Old 12-08-2003, 09:17 AM
Elombard's Avatar
I think it does have some structural use. They used to bond and rivet race cars. What about that?? Glue and rivet? It will play hell on your resale but I think it would work. and You could remove it for access - nice. I recently replaced similar panels in my car, I just needed some smaller sections. I bought them from a wreck mail order. I have seen the panels available out of post 76 cars on the board a few times. Might try a WTB add. If its just a hot rod like mine - go for it. I think the flat panels look trick.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-08-2003, 09:28 AM
