911-4 cylinder?
does anyone have any info on this engine
what sort of info are you looking for?
And which years, the early years or the '76 model?
From the Parts Obsolete (http://www.partsobsolete.com/Outlaws/cab.htm) web site:
"Engine The engine is unique, it was designed and built by Advanced Performance Engineering, lead by Dean Polopolus. It is a 911-4, an innovative and powerful 4-cylinder 911 type engine, case, and components. A lightweight high performance engine, the 911-4 is based on proven components of the standard 911 engine. The engine is 2250 cubic centimeters, with a bore and stroke of 97mm x 74mm. The pistons are Venolia, the rods are Carillo and the cams have 906 profiles. The 911-4 runs 48 IDA Webers on top of 3.o ltr twin plug heads. The engine has a unique sound since it does not fire at 180-degree intervals, rather at 120, 240, and 120. The distributor is a late Carrera 2 unit that has been modified to run a German Bosch pulse generator. A pair of Bosch CD boxes fire the motors at just under 11 to 1 compression. The 911-4 runs 24 degrees total distributor advance and dynos out at 220 plus reliable horsepower. "
Fender,
Do you mean a 912 (911 body with a 356 engine) or the wierd 356ish type car that had the chopped 911 engine ? they're two very different motors.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
