Gon fix it with me hammer
svandamme's Avatar
vin - engine number
hi folks,
small question , i've heard about cars with matching VIN and engine numbers, but how can you tell if they are matching?
do they have matching digits or something?
9113310111 is my VIN
but the number on engine says
901 106 101 5R
doesn't seem to match at all, does this mean my car doesn't have it's original engine?
greetz,
Stijn
Stijn Vandamme
BIMDIESELBMW116D2019
Old 12-08-2003, 06:51 AM
Friend of Warren
You are reading the wrong engine number. The 901 number is the part number of the case. The engine number is on a flat vertical surface on the right hand side of the fan housing close to the oil sending unit. Once you have that number you check to see if the VIN and the engine number are from the same years. You need a book that lists both like Wayne's rebuilding book or the Porsche Red book.
Kurt V
Old 12-08-2003, 06:54 AM
MarkP's Avatar
You will need to order the original Certificate of Authenticity from Porsche. This is often called the Kardex (cardex???). Do a search and you will find a lot of threads on this subject.
To clarify - it's not that your chassis and engine numbers match each other it's that they match the kardex.
'60 356 Roadster Race Car
'67 911S Race Car
PRC Toyo Spec 911 Race Car
Old 12-08-2003, 06:57 AM
svandamme's Avatar
thx for the quick answer, i'll have to look into this
Stijn Vandamme
Old 12-08-2003, 07:02 AM
Cool
Wayne's 911 BBS is amazing.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-08-2003, 07:05 AM
svandamme, I just noticed that you have your car listed as a 1972, yet you have posted a VIN that indicates a 1973 model. You might want to start your search there. Mike
Mike B.
'72 911E Coupe
Early "S" #1065
Old 12-08-2003, 07:08 AM
svandamme's Avatar
nope
made in 72, but model year 73
Stijn Vandamme
Old 12-08-2003, 07:28 AM
Re: vin - engine number
hi folks,
Stjin,
The engine number will read 633XXXX. The 6 is for 6 cylinder engine, the 3 is the 'S' model type, the next 3 is for '73 model year, and XXXX is the serial number of the engine. Looking at the Early S registry list I have, the car with VIN 9113310109 (which is two numbers away from yours) has engine # 66330275. Assuming this car is numbers matching, the number on your engine should be somewhat close to this. Understand the engines weren't put in cars exactly in order and there were S coupes and targas made at the same time with the same engines.
Mark is right the only way to know for sure if you have a matching #s car is to obtain a Certificate of Authenticity from Porsche Club.
Brian
'73 Carrera RS
'71 911S coupe 'Patrick'
'16 Cayman GT4
'91 C4 coupe
Old 12-08-2003, 07:42 AM
svandamme's Avatar
thx Brian , i'll have to look where the real engine number is
so you found where 0109 is ? is it in the States? 0110 is in Hamburg .
anybody has seen 0112??
need one more for a game of poker
Stijn Vandamme
Old 12-08-2003, 07:53 AM
3.2 CAB's Avatar
Looks like it was number 101 one out of 925 made. Your engine # should fall in the range between 6339001-6339136 and it has a 4spd Sportomatic. This sound right to you?
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-08-2003, 07:56 AM
svandamme's Avatar
not at all , mines has a 915 gearbox
Stijn Vandamme
Old 12-08-2003, 07:58 AM
Glad to help. Yes, 0109 is here in the States. It is located in Ohio. The next closest is 0115 which is in California.
Brian
'73 Carrera RS
'16 Cayman GT4
'91 C4 coupe
Old 12-08-2003, 08:26 AM
What?!?!
DonDavis's Avatar
nope
Your car was built in '72 but that does not mean its a '72. Your car is a '73. That's been going on for decades. Build a vehicle in the later part of a year (72) and call it the next year (73). Someone else can elaborate on why.
Your engine (633XXXX) number is located on the right vertical surface of the fan shroud. The numbers are smaller than the part # your listed above. Probably half as big and covered in grime. I think the engine type is going to be 911/53 or 911/63. This # is located on a horizontal surface just ahead of the engine number. Also covered in grime and harder to see.
