Send a message via AIM to air-cool-me
2nd pump for 930?
Alright... so right now i have a SC pump up by the fuel tank..
I have been told the mild 3.3T will need a second(ala factory setup)
The bosh part number on the second pump is 61979
and the Porsche parts numbers for the rear pump vs front are different..
so is the rear pump higher pressure? can i use the extra SC pump i have in line with the front one?
or do i need a fancy "turbo" pump?
thanks
-nick
SWB
Old 09-19-2005, 10:46 AM
WydRyd's Avatar
Stick to the tried and true. Two 930 pumps in series.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-19-2005, 07:31 PM
Thank you for your advice.
according to the PP catalog the front pumps are the same.
so i guess even if i was going with the "tried and true" i would only need one.
looks like the rear one is over $400
just wondering if there is an alternative... considering thats about twice the going price of any aftermarket pump.(walbro 255lph 80psi)
SWB
Old 09-19-2005, 08:42 PM
