-   -   930 shift linkage adjustment - same as 911? (http://forums.pelicanparts.com/porsche-911-technical-forum/138807-930-shift-linkage-adjustment-same-911-a.html)
briankeithsmith 12-08-2003 11:34 AM
Is The shift linkage adjustment procedure described in the tech article on this site the same for a 930 transmission?
911 Shift Linkage Adjustment procedure
john walker's workshop 12-08-2003 12:37 PM
basically, yes. instead of holding the shifter to the left as you turn the coupler to the right, hold the shifter to the right and turn the coupler to the left, with trans in neutral, and shifter centered fore and aft. tighten nut and bolt, and you should be good to go.
