-   -   Generic torque specs - various bolts (http://forums.pelicanparts.com/porsche-911-technical-forum/138851-generic-torque-specs-various-bolts.html)
scca_ita 12-08-2003 04:04 PM
Are there generic torque specs for specific size bolts?
i.e.
4mm = ?ftlb
8mm = ?ftlb
10mm = ?ftlb
etc
My car is going back together this week and I was hoping not to look up specific torque specs.
Jim Sims 12-08-2003 05:17 PM
Depends on metal of screw or bolt and the metal it is being screwed into. Jim
dean 12-08-2003 06:40 PM
In the front or back of most manuals like Bentley or Haynes they will have torque specs
vash 12-08-2003 07:37 PM
with the effort you are about to put into the thing, why not spend the time to look up the torque values? heck just post your questions here, these people are great at giving up the values pronto.
AFJuvat 12-08-2003 07:41 PM
As a general rule of thumb when no torque value is specified -
M6: 14NM
M8: 25NM
M10: 35 - 50NM
As a general rule, you do not want to exceed 14NM on fasteners that use a crush washer (like valve covers) - except of course, the drain plugs.
Double check specifications in the manual, torque values vary widely depending on the application.
AFJuvat
HarryD 12-08-2003 07:48 PM
A quick google search (http://www.google.com/search?q=bolt+torque+values&hl=en&lr=&ie=UTF-8&oe=UTF-8&start=70&sa=N) turned up many web pages.
Here's an interesting one:
http://dodgeram.org/tech/specs/bolts/M_bolts.html
http://dodgeram.org/tech/specs/bolts/SAE_bolts.html
scca_ita 12-08-2003 09:10 PM
HarryD, thanks.
I guess these are maximum torque values. Some are much higher than the specs I know off the top of my head.
Everytime I ask a Porsche tech about a torque value, they always seem to say: "Well thats a 13 MM so it should get xftlbs of torque"
So this is why I asked the original question about generic values.
Randy Webb 12-08-2003 09:45 PM
speaking of being lazy... if there any general guide to the bolt size or nut size based on what size wrench fits it?
Early_S_Man 12-09-2003 12:54 AM
For a torque chart ... go to the following site, then to Tech Info, then Section 10 -- Useful Info, then page 10-1027:
http://www.metricmcc.com/
ChrisBennet 12-09-2003 06:53 AM
Usually:
6mm bolts take 10mm wrenches
8mm bolts take 13mm wrenches
10mm bolts take 17mm wrenches
12mm bolts take 19mm wrenches
There are some reduced size nuts on a 911 motor. Some 915 transmissions are bolted to the motor with 10mm nuts that take a 15mm wrench. There's another nut like that that holds the rear engine bracket to the case. Exhaust nuts are another place you may find reduced size nuts i.e. 8mm that take a 12mm wrench.
-Chris
HarryD 12-09-2003 08:01 AM
Warren,
Very nice.
Randy Webb 12-09-2003 10:30 AM
Thanks, Chris.
