Porsche Crest Warm up regulator adjustment
I was hoping that someone out there can help with a small question about warm up regulator adjustment. I have found some valuable info on WUR adjustment on Pelican Parts and on other sites but very few photos of the "plug" that requires moving in or out in the adjustment process. Is it the small diameter plug/pin on the top side of the WUR or the large plug on the underside? I am a bit confusedand your help would be much appriciated.
Todd ('79 911SC)
Old 12-11-2003, 03:47 AM
Somewhere in the Midwest
MotoSook's Avatar
Hi Todd, welcome to the board.
The pin/plug you see on top is the one you want. There are cut-out views posted on this BBS somewhere. You can make it adjustable too! If you knock it into the WUR, there is a good chance you'll overshoot your pressure. A screw and pin like that described by Pano (search) will allow you to back the plug/pin out without taking the WUR appart if you overshoot the pressure.
Old 12-11-2003, 04:33 AM
Thanks Souk. I will search for the article you mentioned and give it a go ASAP. Once again thanks.
Todd
Old 12-11-2003, 04:39 AM
