18 " wheels for 85 Carrera
is it possible to put on a set of 18" wheels on a 85 Carrera, if so, what would be the rims size and tires? Any body with some pics ?
eyue
85' Carrera Coupe
93' 3.6 Turbo
Old 12-28-2003, 06:26 AM
eyue, You can fit 18's on your car. The rim widths are 8 front and 9 rear with a 235/40 tire in front and a 265/35 in the rear. There are others that fit but this is the widest!
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 12-28-2003, 06:33 AM
With those wide tires, will I have to shave some of the inside fender ? I am afraid these tires might rub, due to my lower setting !!!
eyue
85' Carrera Coupe
93' 3.6 Turbo
Old 12-28-2003, 07:01 AM
MuffinMan's Avatar
You will most likely need to roll your front fenders, and probably your rears, also. Of course, you won't know for sure until you mount the wheels/tires.
Rob Fusi
77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s |
GTC Motorsports
Old 12-28-2003, 07:11 AM
911 user
Milu's Avatar
Are there any downsides to fitting 18s to a Carrera?
I would guess one would end up with a much harder, less absorbant ride. Possibly some wheel damage if its used on a lot of potholed roads.
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 12-28-2003, 07:44 AM
Actually I was thinking of performance, it definitely will looks great, but how much will it slower the car, plus I do not have power steering, any downside on the steering column ? It is quite heavy during parking as it's now !!!
eyue
85' Carrera Coupe
93' 3.6 Turbo
Old 12-28-2003, 07:49 AM
Mikkel
Guest
Posts: n/a
With 235/40x18 at the front you'll most likely get a lot of tramlining. I would also expect the steering to be rather heavy.
I think Bill Verburg runs 18s or is it 17s..? Can't remember, but he has BIG wheels that's for sure. I think the has rolled his fenders.
Also there was a thread recently on 18s for narrow cars (SC/Carrera). Try to search for it.
BTW I just downsized from 17s to 16s on my Carrera
Old 12-28-2003, 08:09 AM
One of the reasons for me on thought of changing to 18 " is due to the availability of tires in 16 ", though I love the looks of the black fuchs, the tires just looks too thick.
eyue
85' Carrera Coupe
93' 3.6 Turbo
Old 12-28-2003, 08:29 AM
The biggest downside is ride quality with an early suspension. I can tell immediately with an increase from 16 to 17" rims. Going to 18" would be brutal. For performance and track use, it is worth the ride quality sacrifices I suppose. For street use on a car's suspension that was designed 25 years ago, it may be a bit much. Many of the newer cars are designed with much larger sized wheels integral with the suspension. In fact, I think Porsche put out a factory bulletin indicating not to install 18" wheels on these early car for problems. People still do it and it works though. You might want to somehow borrow a set to try out before purchasing, at least if you value not having a skipping cd player.
Old 12-28-2003, 08:42 AM
many thanks for all the thoughts GUYS................
eyue
85' Carrera Coupe
93' 3.6 Turbo
Old 12-28-2003, 08:46 AM
