-   -   Thread size and Pitch for hard brake lines? (http://forums.pelicanparts.com/porsche-911-technical-forum/139223-thread-size-pitch-hard-brake-lines.html)
jpachard 12-11-2003 07:01 AM
Hey All, Does anyone know the thread size and pitch for the fittings on the end of the hard brake lines? I'm planning on making some female ends that you can put over the lines while you have the calipers disconnected in order to stop brake fluid going everywhere. Thank you in advance!
Cheers, James
Tim Walsh 12-11-2003 07:08 AM
I know the stock size for the hard lines on S calipers are either 10x1 or 11x1 I can't remember which. Not sure which brakes you have or if they're the same.
ChrisBennet 12-11-2003 07:13 AM
They are 10x1. I have been looking for caps for this application and all I can find are plastic ones. I would love to to have 4 caps. ;)
-Chris
jpachard 12-11-2003 07:17 AM
Hey, Thank you both. Chris, I will make some tomorrow and I can get them to you on Sat. if you can come. If not, I'll ship them to you.
Cheers, James
Chris, if you can't make it do you have a jack thingy I can borrow for my engine drop? Michael said he could pick it up from you tomorrow at lunch.
Cheers, James
ChrisBennet 12-11-2003 07:29 AM
James,
No rush on the caps, I'll be seeing you at some point this winter if I don't come down for the engine drop. I'll be doing a couple of motors this winter, maybe you can come up for one of those?
I'll email you about the jack thingies.
-Chris
Bill Verburg 12-11-2003 04:22 PM
As Chris stated 10x1.0
What caps are you looking for Chris?
Neilk 12-11-2003 04:27 PM
If you have alloy S calipers, use the brake bleed valves on the top of each caliper. It worked for me.
Edit... I connected them to the end of the soft lines.
