Senior Member
Jdub's Avatar
Paul:
I rebuilt my with fresh circlips and gaskets. I also swapped the CVs sameside, side to side (i.e. did not move either CV to the other axle, just swapped them on the same axle.
I think I am outta luck though, as the races appear dead. I grabbed a pair of used axles with 40K on them in the Classifieds. I will put fresh circlips and gaskets on them along with SynPower 985 synth/moly grease.
As to the M8x50 bolts, I now have the 12-points instead of the old set. Pelican sold me lockwashers at $0.25 per, and so I guess the Schnorr washers are out.
John
'78 Targa | WANTED TO BUY - NORTON COMMANDO PARTS - PLS MESSAGE.
Old 01-28-2004, 02:21 PM
John:
Let us know how the spring plate angle calculator works for you. Remember..the better the input numbers ( individual rear corner weights, etc)...the better the result.
--Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-28-2004, 06:25 PM
Senior Member
Jdub's Avatar
Wil:
I am sure that any discrepency would have to be traced to inaccurate measurements by me (user error). The calc is a Godsend.
And let's remember, "It's a poor craftsman who blames his tools" (or to paraphrase, the tools he borrows ;>).
This weekend is the time, hope to lower it prior to the Super Bowl.
John
Old 01-29-2004, 07:28 AM
Neither being defensive nor being a wiseguy....I understand. I posted as I did, knowing that *in general* the calculator works pretty well...but with all that rubber compressing and twisting, and perhaps a little dose of over/under estimating weights...it still *can* be wrong when we're looking for that final 1/4".
As I said...not a problem...just being cautious
---Wil
Wil Ferch
Old 01-29-2004, 12:17 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
"The Ferch Method" worked perfectly for me, the first time. Thanks again Wil, and good luck John!
Old 01-29-2004, 12:32 PM
Binge User
Schrup's Avatar
The new CV joints went in easy, I plan to use this high strength Loctite instead of lock washers. I tried to get & keep all the bolts & holes clean for a good bond. Next time I find time I will remove each bolt, loctite it & torque it back in.
Paul
Old 01-30-2004, 09:01 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I'd stick with the serrated Schnorr lock washer. Proven method. Others have gone with safety wire for added insurance. I'd prefer to simply make a habit of checking the axle screw torque on a regular basis. For instance, oil change intervals? The problem seems to be more common with the M8 axle screws. M10 screws allow a higher torque spec. of around 60 lb-ft. I believe.
That red loctite requires heat for removal once it cures. 262 is listed under Loctite's site as a permanent threadlocker.
http://www.loctite.com/int_henkel/loctite_us/loctite_content.cfm?layout=4&productline=OEM1020&path=Assembly%20Products
Sounds like a miserable job the next time the CV joints or axles need servicing.
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 01-30-2004, 09:27 AM
Binge User
Schrup's Avatar
Kevin, I would like to use the Schnorr washers, but can't find them. Thanks for the web info, they failed to mention that I would need heat to remove them while they were selling it to me.
Paul
Old 01-30-2004, 09:36 AM
FYI- Example of Safety wiring CVs
Old 01-30-2004, 09:43 AM
The various "red" locktites pretty much all require heat to get off...I think the Dilivar head studs are the same way...
Now "blue"...that would be the ticket for a lock-washer replacement yet still be able to use normal "tools" to get off....
---Wil Ferch
Wil Ferch
Old 01-30-2004, 09:51 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I've not seen the type used for the axle shafts. Are they serrated (on both sides or just one side) or a smooth finish disc? Schnorr is actually the manufacturer, not necessarily the type of lock washer. They're also sometimes called Belleville washers.
Best description of them i've seen is at Metric and Multistandard Components Co. Thanks to Warren/Early_S_Man for the info. on this company years ago.
Disc Springs
Ribbed/Serrated Springs
You can view the whole catalog by going to
http://www.metricmcc.com/index.htm
and then clicking on the little red book icon on the left sidebar.
McMaster-Carr carries the Belleville washers, but the metric selection isn't as good.
www.mcmaster.com
and type in "belleville washer" in the command line @ the top left of the page.
Hope this helps?
Kevin L
Past: '87 Carrera
Old 01-30-2004, 11:47 AM
Binge User
Schrup's Avatar
Thanks Kevin, I just ordered 100 8mm, 50 10mm, & 50 12mm, all minimums about $10 apiece. They have a $25 minimum, that's why I ordered the 10s & 12s. PM me John if you want some, I'll give you a better deal than $.25 apiece.
Paul
Old 01-30-2004, 12:25 PM
Randy Webb's Avatar
Paul -- You realize that the coeff. of friction in the threads will differ when you use Loctite, don't you? Thus the stress will differ on the bolt for a given torque... so they will not be correctly torqued.
Now, I don't know if the difference will be an important one, but it might be. I also agree re the red vs. blue. But I wouldn't do it at all.
Old 01-30-2004, 10:20 PM
