Steam From Defroster??????
Drove the car to diy car wash to clean underside of engine and trans. Sprayed all around underneath.
On the drive home, whenever I made a turn, steam would come out ot the defroster vents.
Does this mean something? I'm afraid some part of the heater duct work has rusted thru. I know there are about 3 quarter sized wholes on the outer rocker but these shouldnt allow water into heating ducts.......right?
Old 12-13-2003, 01:43 PM
M. Hendrix's Avatar
more likely a seam in your heat exchangers.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 12-13-2003, 01:49 PM
Cool
maybe the fresh air vent drain is clogged
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-13-2003, 01:53 PM
Heater exchangers are SSI. Tho very good quality, I'm sure there is a way water under high pressure can be forced into them. Hope thats whats causing the steam. If so, NO FIX required.
Cas is a 72 911.
Where is the fresh air vent drain?
Old 12-13-2003, 01:59 PM
the fresh air manifold encloses the mesh outside vent. at the bottom of the manifold on my car is a plastic flex accordion type hose that extends under the car.. mine sticks out about 1/2 inch down under.. perhaps an eyeball from down under
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-13-2003, 02:16 PM
