As of September 22, 2003 I became a proud owner of a 1981 Porsche 911 SC (factory Sahara Beige). I have two questions that I hope the experts here can help me with an answer.
My car averages 17.90 MPG (smooth highway driving) and I was under the impression that beginning in 1980 that these cars were rated at 29 MPG for the highway. I am using Chevron Premium fuel (91 octane). I have just replaced the Oxygen Sensor with no improvement. My first question is: what is the likelihood of the cold start valve leaking during normal operation / has anyone else found their valve to be leaking? I certainly do not wish to remove the valve unless there is a strong possibility that this could be at fault. The car starts well both warm and cold. Second question concerns the Bentley 911 SC Service Manual: when looking at the wiring diagram, the letters "NCA" is listed connecting to the Oxygen Sensor. These same letters are used in many different areas of the electrical diagrams and I can find no reference to this in the legend. What does "NCA" represent?
Daryl G. 1981 911 SC - sold 06/29/12 |
i hate acronyms so i cant help you there.
but my book list three possible causes of bad gas mileage: leaking injectors, leaking cold start valve, and improperly adjusted air fuel mixture. so line up the easiest first and work down the list. but i get crappy gas mileage, because i drive like a fool.
poof! gone |
oh yea, i think you are supposed to post some pictures. hurry before the picture police show up.
poof! gone |
Check your plugs. If the cold start valve is leaking, you most probably are running rich and your plugs will show this (dark and soory). Remember, a rich mixture will is not only caused by a leaking cold start valve, idle CO% and incorrect system and control CIS pressures will also cause a rich mix.
Sorry, don't know what NCA is either.
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
I think you can check the cold start valve for leakage the same way you test the injectors for the correct spray pattern. But I also read there are some worse symptoms caused by a leaky cold start valve than bad mileage. I'm not quite sure if I have experience with that or not though because checking mine for leaks is still on the to-do list. If i get motivated I'll look at the CIS trouble shoot book in a little while and post back. or hopefully someone with practical experience will post and teach us both something
1979 911 SC Targa http://www.pelicanparts.com/gallery/Mike_Kast |
