Sonic dB's Avatar
Engine bay release cable
Just recently, when I pull the release cable for the engine bay cover nothing happens. I then have to push up and down on the lid several times before it will release and open.
Is this caused by a stretched/bad cable...or would it be in the release mechanism (latch)?
Old 12-14-2003, 08:48 AM
84toy's Avatar
This happened to mine as well. I relocated the male portion of the latch which just requires loosening the 2 bolts and moving it until it goes in the receptacle correctly. Before I did that I removed the spring on the male portion (just loosen the jam nut and unscrew the male portion) and stretched it out a bit and reassembled it. Now it pops up perfect
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 12-14-2003, 09:04 AM
Sonic dB's Avatar
Thanks Paul...that sounds like a solution.
Old 12-14-2003, 09:08 AM
vash's Avatar
i was having a hell of a time too. then i noticed the strut was really weak, i changed that, problem solved. but 84toy has the best first fix.
poof! gone
Old 12-14-2003, 12:01 PM
kokkelix's Avatar
I had a similar trouble. Replacing the rear deck lid shocks solved my problem.
// sk
Old 12-14-2003, 12:45 PM
84toy's Avatar
If the lid won't stay up, it's the shock. If it won't jump up that first inch when released it is an alignment or a spring issue.
Paul S
Old 12-14-2003, 02:57 PM
