Alternator and fan housing question
I have a 81 SC engine with a Marchel alt in it. The Fan housing is not the right one as the alt sticks to far out the back of it iterfering with the fit of the air baffle. What are my options? I must note the alt needs a rebuild anyhow so I need a new alt anyhow. ANy ideas
Ben
77 911 3.0
75 914-6 2.7
Old 12-10-2003, 02:58 PM
Any body?
Ben
77 911 3.0
75 914-6 2.7
Old 12-11-2003, 05:25 PM
carreradpt's Avatar
Ben, I'm somewhat confused. Did you remove this from the car or did you purchase the motor? My thought would be that the alt is not mounted completely to the housing. That is possible. The screws on the back are tough to get straight thru until they are seated. Can tell by the fan rubbing on the housing. Just a guess. I think the Marchal was standard on the 81's, might be wrong.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 12-11-2003, 06:16 PM
Student of the obvious
LeeH's Avatar
I just removed my fan and housing for powdercoating. Make sure that the connectors on the alternator are not interfering with the air guide. When I first reassembled mine I had the leads pointing down. I had to loosen them and point them to the side. If I hadn't take it apart myself I would have sworn it wouldn't all fit back together. My knuckles and back haven't recovered yet, but it looks great!
Lee
Old 12-11-2003, 07:05 PM
I bought a basket case 3.0 and the alternator was thrown on top as a core. There was no airguide so I bought one from a friend and when I went to hook it up after the major overhaul the air guide would not fit over the end of the alt. The alternator sticks out the backside of the fan housing to far for the airguide to fit on properly. I am thinking that the housing is not the correct one for the alternator as it seam as thogh it is not thick enough at the rear portion where the air guide mounts. Causing the alternator itself to interfer with the airguide. Let me know what you think
Ben
77 911 3.0
75 914-6 2.7
Old 12-12-2003, 03:55 AM
Any help would be great. Did they make different offsets or back spaced fan housings? I would like to figure this out before the engine goes back into the car in a month or so>
Ben
Old 12-14-2003, 11:04 AM
304065's Avatar
Yes there are at least three versions. The "R" number eg 0R, 4R, 5R, they are different. Carrera alternator takes a shroud with a 930 5r or later
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 12-14-2003, 07:34 PM
47silver's Avatar
i think if you check prior posts you will find some answers.. i think that the voltage regulator interferes with the shroud and you can eithe buy a new one or notch out the one you have..
1975 911S Targa
Silver Anniversary Edition
Old 12-14-2003, 09:18 PM
Cool
I notched mine when I went from external to internal reg
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-14-2003, 09:29 PM
mY ALTERNATOR Does not have an enternal reg. Thats what is so confussing. The alternator sticks out to far that is the major deal (on the back towards the front of the car) the fan side is fine.
Ben
Old 12-15-2003, 03:55 AM
