Oil Fumes Coming into Car
Hi, I am looking for a little help on an issue I have. Ever since I put in my new oil thermostat I have been noticing oil smoke coming through the vents in my '71s. I can't see any oil coming from the thermostat or the oil pressure regulator, but I know somehow oil is getting to the heat sinks on the top of the engine and burning off and into the vents. I want to take the engine shroud off, but it looks involved. I have carbs so its pretty easy to get at, but there are a lot of bolts and connections holding the shroud to the top of the engine. So, I am looking for ideas. I can't even drive the car because I smell like an oil refinery when I get out so I need to figure out something. Pleeeease help.
Zac
'71 911 s Targa |
what's it look like from underneath?
Friend of Warren
Did you replace the oil thermostat o-ring? If not I imagine oil is coming from the thermostat and eventually running down onto the heat exchangers.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Yes, I did replace the o-ring ont he thermostat. I have looked and I don't see any oil around the thermostat. I just looked at that shroud and it doesn't look like any fun to pull off. still searching...
'71 911 s Targa |
JOT MON ABBR OTH
When I had this symptom I found that my headstuds had broken and oil was leaking down onto the exchangers and burning. But this is only my experience...
David '83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)'15 F250 Gas (Her Baby) '95 993 (sold )I don't take scalps. I'm civilized like white man now, I shoot man in back. |
Ouch Groesbeck !!!
1979 911 SC Targa http://www.pelicanparts.com/gallery/Mike_Kast |
Had the exact same problem as grosbeck.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
