Question pwr strng fluid
Help on my 90 C2, the manual calls for ATF Dexron for the power steering. Another manual I have calls for Dexron II. I can only find Dexron/Mercon III. Is there any difference? Will the Dexron III work for my c2?? thanks Bob.
Old 12-19-2003, 02:53 PM
JC930's Avatar
Dexron III is fine for dexron or dexron II. It will say that right on the bottle.
77' 930 turbo carrera silver SOLD
03' SL500 Mercedes Benz white
06' GMC Yukon Danali white
15' LTZ Chevy Suburban black
07' 997 tt black
Old 12-19-2003, 03:28 PM
just newer formulation.
Similar to oil formulation. A manual for a mid 70's car may specify oil that meets API SB or SC specifications, but if you tried to go find that right now you wouldn't be able to because it has been replaced severaly times over the years, I think the current is API SG and SH, that doesn't mean that you can't use modern oils in your old car.
You'll be fine using whatever version of Dexron you can find. Just don't use "Type F" and you'll be OK.
Old 12-19-2003, 03:37 PM
Thanks for the help guys!!
Old 12-19-2003, 07:08 PM
