-   -   correct size tyres for 73 RSR front/ rear? (http://forums.pelicanparts.com/porsche-911-technical-forum/139768-correct-size-tyres-73-rsr-front-rear.html)
adomakin 12-15-2003 08:53 AM
anyone know the correct tyre sizes for a 1973 RSR?
front and rear? i have heard that getting the rear tyres is a problem.........
Bill Verburg 12-15-2003 09:16 AM
Front
230/600 on 9x15
Rear
260/600 on 11x15
adomakin 12-15-2003 09:20 AM
bill, what would the 600 part match to in todays sizes? 60 profile perhaps?
nick-moss 12-15-2003 09:40 AM
285/40 x 15 is a road tyre size, but it went out of production many years ago
GeorgeK 12-15-2003 09:47 AM
Adomakin,
230/600 means 230 mm wide, and 600mm in diameter
260/600 means 260 mm wide and 600 mm in diameter
This racing nomenclature is helpful when setting gearing for a particular track.
Bill Verburg 12-15-2003 09:48 AM
There are no exact modern equivalents, the #s work out to be pretty close to 225/35x17 and 255/30x17. But there are no tires available in those sizes.
235/40x17 and 265/35x17 are the closest modern street tire equivalents. At least in the specified tread width and overall diameter.
nick-moss 12-15-2003 09:50 AM
Hoosier do some DOT tyres that are very close to the original sizes, but they are not legal in the UK.
adomakin 12-15-2003 09:54 AM
i can get my hands on either 255/60/15, 275/60/15 or 265/50/15 tyres from new, how do they compare?
nick-moss 12-15-2003 09:55 AM
Check out the rolling circumferences here
Bill Verburg 12-15-2003 10:09 AM
a 230/600 is ~9"widex23.6"tall
a 260/600 is ~10.25"wide x23.6" tall
the tire you specified are all way too tall
255/60 is ~ 10 x 27"
275/60 is ~ 11 x 28"
265/50 is ~ 10.9 x 25.5"
Any of them are very poor choices
adomakin 12-15-2003 10:18 AM
how about a 265/40/15? i think i can get them new?
Bill Verburg 12-15-2003 10:37 AM
If you can find some(I can't) 265/40x15 are ~10.4"wide x 23.4"tall. They would be a good size for the rear.
adomakin 12-15-2003 10:38 AM
thanks very much people. bill, ill let you know if i can get them 265/40's if you are interested
Early_S_Man 12-15-2003 11:28 AM
285/40 - 15 ... 23.98" for front on 9 x 15 Fuchs
345/35 - 15 ... 24.53" for rear on 11 x 15 Fuchs
are a good match for the street on an RSR clone ...
The 345's are still available, and occasionally I hear about attempts by Pantera folks worldwide for a group buy of special-run batch of 285's.
Bill Verburg 12-15-2003 11:41 AM
I am certainly not interested in those tires but I am curious as to what manufacturer makes them.
The only 345/35x15 that I know of is the PZero at 13.9" x 25.9" an 11" rim is at the minimum end of the recommended range and as Warren pointed out there is no available mathing front.
nick-moss 12-15-2003 12:01 PM
I have a brand new pair of Yokohama AV1 345/35 ZR 15 for sale.
RarlyL8 12-15-2003 05:48 PM
I'm running 255/45-15 front 345/35-15 rear.
Never heard of a 265/40-15.
Yokohama no longer produces any of those sizes (255, 285, 345) in 15 inch.
23.6" is a short tire. You may want to consider the gearing you have when choosing tire sizes. An inch in tire hieght makes a noticeable difference in the final gear ratio. Going to a 17" rim with ultra low profile tires will also help out the handling.
adomakin 12-17-2003 11:19 AM
will a 345/35/15 fit under a 73 rsr arch? if it does then im all for it!
RarlyL8 12-17-2003 06:00 PM
Depends on the wheel.
Should work fine using the right width and offset.
Jack Olsen 12-17-2003 06:44 PM
I'm running 315's with a one-inch spacer. If you plan accordingly, it shouldn't be a problem at all.
Keep in mind, though, there's a point of diminishing returns, in terms of drag, where the width isn't getting you anything, if you don't have a whole lot of extra power to push it -- at least when it comes to lap times.
Rarly doesn't have that problem, of course. ;)
adomakin 12-17-2003 11:07 PM
thanks blokes. by the way, just bought some dodgy looking mag called excellence or excellent or excitement or something that had a tatty old black 911 in it..................................not bad jack!
Jack Olsen 12-18-2003 12:14 AM
Thanks.
http://bender.annenberg.edu/pelican/JackOlsen/Rear.jpg
Now try to imagine adding a full inch and a quarter, or five centimeters, to each of those rear tires.
You're talking wide. :cool:
adomakin 12-18-2003 11:42 AM
are them lights an RSR spec light jack or your own breed?
Bill Verburg 12-18-2003 12:36 PM
You're talking wide
and you're talking camber, how much are you using? It looks really radical for a street car.
Jack Olsen 12-18-2003 09:23 PM
The lights are 911R style. Not correct for a 911 RSR.
I think the camber is about 3 degrees, maybe less. I'll have to look it up. The big wheels and the shape of the flares make it look more exaggerated, I think.
adomakin 12-19-2003 01:42 PM
going back to the big tyre issue, the inner offset on my banded 11x15 fuch's is 121mm. does this mean that i should be able to use 345/35/15's?
RarlyL8 12-19-2003 06:07 PM
With only 4 and 3/4 inches of backspacing you need to measure from the mounting surface on the hub to the suspension arm bolts and see how much room you have.
Yokohama 345s are 3/4 inch wider than Pirelli 345s. Makes a big difference in this tight fitment.
j911brick 12-04-2025 05:33 AM
I'm resurrecting this thread. These tires should be perfect. But is there a us distributor?
https://www.longstonetyres.co.uk/23-59-15-michelin-tb5r.html?cc=ghqf7v5o9v3n5dv212fr1ubtbi-1764854289
j911brick 12-04-2025 08:41 AM
Will 15" wheels fit over 930 calipers/suspension?
Bill Verburg 12-04-2025 12:30 PM
for 15" Fuchs, yes for 8" or wider
these are 11s
http://forums.pelicanparts.com/uploa...1764880169.jpg
7s need a spacer or shave the fins on the caliper
Bill Verburg 12-04-2025 12:38 PM
Here's a survey of most of the historic type tires
http://forums.pelicanparts.com/uploa...1764880673.jpg
j911brick 12-04-2025 03:02 PM
these are 11s
