how do you best clean the WUR screen?
That is the question.
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 12-16-2003, 04:23 AM
Senior Member
Jdub's Avatar
Mike:
Do you mean the rotating "fan" in the WUR? That is a somewhat delicate item, but I'd think you could douse it with WD-40 without worry.
That said, wait for someone who knows more to chime in! I dimly remember cleaning this item sometime back and using cleaners less caustic than, say, Gumout or Brake Cleaner.
John
'78 Targa in Minerva Blue
Old 12-16-2003, 06:45 AM
the screen on the fuel inflow side of the warm up regulator
Its the top hole. Since the fuel flows in I didn't think it was a good idea to blow it in. I thought it would be better to clean it out from the back. The other side doesn't look to clean either. I was wondering how best to get inside. or if thats a bad idea.
What happens if I remove the four screws in the bad picture above. will that get me any closer to the internals? Idealy it would be nice if I could backwash it with carb cleaner. I figured I'd ask before I break something.
1979 911 SC Targa
Old 12-16-2003, 05:47 PM
