air pump advice
i have a 79 sc 3.0 all stock i live is kansas so there are no laws on smog. i want to get more room in the back i just need to know how to plug off the distribution pipes and the injection.
by doing this i think i will have to change my air/fule mix? i do not know how to do that . thanx corey |
Take out the pump and lines and plug holes in heads with 10mm plugs with 1-mm thread pitch.
Thank you for your time, |
You can buy some "caps" for the cylinders under the car where the air is injected into the cylinders and remove everything else. I dont believe you will need to adjust air/feul but I could be wrong-- I didnt -- you can buy the plugs for cheap I just did it-- have fun.
Dean 1978 SC Targa Euro 1966 911 Coupe Restored/Burned/Sold - In that Order |
were do you get the plugs at ? will this give me any more hp?
Just call Pelican in the AM and explain to them what you want. They will hook you up.
no --- no more noticeable hp-- Sorry
well i got all of the air pump stuff off tonight. i am having a time finding the bolts to go back in but i think i will find them. thanx
corey |
did you call Pelican?? If they dont have them others do
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Get Mercedes Benz Transmission drain plugs. They are cheap.
Keeper of the Titanium Monkey 1975 911S (sold) 1973 911 w/3.2 (sold) 1983 911SC targa (sold) Looking for a 987.2 or 981 Cayman |
Go Speedracer, go!
1981 SC ROW Coupe |
After you take the air pump out and dicsonnect the rubber tube that connects to the pipe assembly in the engine compartment, you can leave the air pipes in place. They won't effect the performance at all plugged or unpluged.
Here in CA, we put the air pump in every 2 years for smog, then remove it and run the car 'til the next time without plugging anything and there is no difference in performance. The pipes don't acutally go into the cyclinders. They inject air into the exhust path for some unknown reason. All I can figure, is that it somehow dilutes the exhaust emmisions so it can pass smog inspection.
If it doesn't leak, you're out of oil. If you took a picture of a Porsche and put it in your shirt pocket it would leak oil on your shirt. Screw Flanders.... I'm goin' to Moe's. |
Senior Member
Be sure to save all the bits for the next owner.
John
'78 Targa in Minerva Blue |
