Ok, What is the secret to removing the seats from a 82 911? There are (4) bolts holding the rails to the floor pan. I can access the front bolts (10mm) and those came out fine. Slid the seat forward and tried to do the same with the rear bolts and the same socket doesn't fit over the bolt. I tried an 11mm socket but doesn't fit into the seat rail channel. Do I need to get a U-joint drive?
Any hints/advice? Thanks
Harlan Chinn Pacific Northwest Region 1998 Carrera S ArcticSilverMetallic 1982 911SC PazificBlauMetallic |
the rears should be 10mm as well, you might have to grind down the socket a bit to fit (what I had to do).
Amir '83 911SC |
Try a 1/8" drive. The sockets are shorter and narrower. If nothing else I would get a thin walled socket before grinding it down. Then you are set next time.
It's interesting, my bolts are allen head bolts. The same ones are in the seat rail on the bottom of the seat. I wonder if you have a hack or if that's how they were in 82...
GruppeB #935 84 Carrera Targa B.A.S.T.A.R.D. (for sale) 82 SC RSR Project (on ebay) 95 Dodge Ram 2500 03 Toyota 4runner |
Bolts were stock, allen heads are a retrofit.
Get a "skinny" socket set - I found one and was able to pull out the back bolts. That's a lot easier than grinding a set down IMHO.
- Bill
1982 Porsche 911SC Coupe 1999 Porsche 911/996 Coupe |
Mine were 10mm bolts. Super PIA. Next time I pull the seats, Allens are going in.
Hilbilly Deluxe
I used a Craftsman ¼" drive socket. Fit just fine.
Tom |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
The 1/4" drive fits fine, but can't get enough room to get the ratchet under the seat bottom. What a PITA. Will need to replace the hex bolts with allen heads screws
Try using a 1/4" wobble extension on that 1/4" drive socket. Worked for me!
Howie 79SC |
And then when it's time to put the seats back in, use socket head cap screws so you don't have to fight with this problem anymore...
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
What?
You guys did what I did. 10mm on the front, then slide the seat all the way forward and use 1/4 on the rear.
Tom J. 911SC Cab SCWDP CaymanS |
Mike
If you have to, use a dremel to cut a slot into the top of the bolt. Them use a flathead screw driver to unscrew it. Big slot, big screwdriver.
Certified Pre-Owned
Get behind the seat when its all the way forward and give it a good solid kick to gain some clearance.
'84 Carrera Coupe |
BG,
Stop trying to make sense, and quit calling me Shirley!
2001 Turbo |
Harlan:
I believe socket head cap screws ( aka allen bolts) were always factory for this model year range of cars....at least for the later 3.2's. --Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
A Craftsman 3/8 in 10 mm socket functions alright to remove the bolts that hold the seats in my '82. The socket fit is a bit tight though.
Thanks for the hex socket cap idea. This could speed up seat r/r as long as the hex wretch clears the seat back. -Brad
'82 911SC Coupe |
Unregistered
I use a racing seat for DEs and AX and switch back to the stock seats for regular driving so I swap out my seat a lot. The first time was a little bit of a bear, second time was much easier after I replaced the cap screws (bolts) with socket head cap screws (allen). I have a special hex key (allen wrench) I use that I cut down for just this use. I also have the small stub left over, I can insert it into the socket head cap screw and use a cobination wrench on it if it gives me a hard time.
Seems like the hottest set up would be a hex key stub and a small ratchet wrench to turn the stub. I haven't gotten that fancy with it but I might try it one of these days. I can swap out the seat in less than 5 minutes now, installing the harness bar and 5 points take a little longer
