adomakin's Avatar
930 engine casing exclusive to 930?
is the 930 turbo engine casing the same as any other engine?
just curious
andy
uk
Old 12-17-2003, 12:06 PM
it can be used on a 3.3 turbo, 3.2 carrera. you will have to get the correct engine sump plate to work with those motors' oil pumps, but otherwise they are basically the same. small differences on engine stud mount positions, lengths, etc, but overall interchangeble
Old 12-17-2003, 12:17 PM
adomakin's Avatar
its not the same as a 3litre sc is it?
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 12-17-2003, 12:23 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
isn't the 3.0 turbo case different than the SC/3.2/3.3 turbo case? I belive wayne mentioned it has 6 flywheel bolts instead of nine?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 12-17-2003, 12:28 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
The early turbo case i believe is the one that can except a smaller crank like the 2.7's i believe. And the sc has a 930 part # on it's case just like the carrera and turbo.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 12-17-2003, 12:54 PM
adomakin's Avatar
hmm...
Andy
Old 12-17-2003, 11:10 PM
"SC cases same as carrera"- yes and no. in late 1983, porsche came out with the 911sc case that has no sump plate- just like 84 and later 911 and turbo models. Some argue that those cases are stronger. I would agree that if you are building a really strong turbo engine, it would be preferable, but not really necessary . 1978-1983 (early) models had the sump plate design for both the sc and the turbo. All use the same bearings and if building a turbo motor in an SC or Carrera case, care needs to be taken regarding oil pump clearance. the turbo has a huge pump and the case needs internal grinding to clear it
Others are correct regarding the 1975-1977 3.0 Turbo case- it uses the "smaller" 6 bolt crank.
Old 12-18-2003, 09:13 AM
BURN-BROS's Avatar
So can 3.2 heads fit on a 3.3?
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 12-18-2003, 09:26 AM
