Front stablizer bar
Hi, I think that is what it is called. There is one in the back also. Well, when I took off the cover for the gas pump in my 77 911, I said what the heck, I will pull off the stablizer bar while i am in the area to POR-15 (Preventive stuff). Anyways, when I went to put back together, I forgot how it is all suppose to go. On the brackets that hold the bar, there is a bolt on each that is welded to the bracket. Where does that bolt go? Do I attach back to the car on the end that has the bushing or the end with the welded bolt. Any pictures would be helpful.
Thanks, David |
Does this diagram help?
http://forums.pelicanparts.com/uploa...1071770044.jpg |
Yes, excellent. Thanks alot.
Thanks Kurt,
I got the whole thing back together Friday night. With the time saved, I actually got to replace my motor mounts also. Thanks again and Happy Holidays. |
| All times are GMT -8. The time now is 01:14 AM. |
