Engine Thermostat
How can I test my engine thermostat. I'm assuming it works fine but would like to know if there is a way to test.
Thoughts?
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 12-20-2003, 07:43 PM
feelyx's Avatar
put it in a pot of water on your stove and heat it up to 83c and watch it open.
Tim in Sac
98 Boxster
87 560sl
04 S2000
Old 12-20-2003, 09:02 PM
feelyx's Avatar
...and don't let the wife catch you
Thank you. Didn't know if putting it in water would hurt something that normally sits in oil.
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 12-21-2003, 10:12 AM
North Coast Cab's Avatar
Easy test if it's not out is to run car until it gets to the 190-200 degree range. When it opens up the lines to the front cooler will heat-up.
John
1985.5 944 GTS
Old 12-21-2003, 10:18 AM
ttweed's Avatar
Actually, one line to the front cooler will heat up (the supply line) even if the thermostat never opens. The other (return line) will stay cool until flow begins in the system, so be sure to feel both of them.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 12-22-2003, 11:01 AM
Early_S_Man's Avatar
Porsche Crest
Guys ... you can't rely on the temp of the scavenge line to tell whether the engine-mounted thermostat is opening or not!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-22-2003, 04:22 PM
