Engine Thermostat
How can I test my engine thermostat. I'm assuming it works fine but would like to know if there is a way to test.
Thoughts?
1999 996 C4 Cabriolet 1997 BMW M3 (Hail) 1985 928 S (Sold) 1982 SC Targa (Sold) |
put it in a pot of water on your stove and heat it up to 83c and watch it open.
Tim in Sac
---------------------------------------------------------------- 98 Boxster 87 560sl 04 S2000 |
...and don't let the wife catch you
Thank you. Didn't know if putting it in water would hurt something that normally sits in oil.
Easy test if it's not out is to run car until it gets to the 190-200 degree range. When it opens up the lines to the front cooler will heat-up.
John
1985.5 944 GTS |
TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 Last edited by ttweed; 12-22-2003 at 11:04 AM.. |
Guys ... you can't rely on the temp of the scavenge line to tell whether the engine-mounted thermostat is opening or not!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
