Certified Pre-Owned
Hi-
Curious if anyone knows if the Bosch motor in the evap coil box happens to be the same motor that is in the front condensor blower up by the front bumper. The one up front fried and I need to replace it. I don't need a new housing and cage fan, just the motor. The Bosch motor lacks a Bosch part number on it. Thanks- BG
'84 Carrera Coupe |
Senior Member
Do a search on this and hope you will find a post from Colin in Toronto. He did his and got the Bosch part number that can be bought over the counter for about 75% less than Porsche sells them for.
Hope you have the fuse in-line with the front motor. Several cars have burned up without the fuse and the factory started putting one in-line to protect it. Joea
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Certified Pre-Owned
Thanks- BG
'84 Carrera Coupe |
Friend of Warren
BG if you don't find the motor you need, let me know. I pulled the AC in my '86 and will make you a good deal on the motor.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Certified Pre-Owned
Kurt-
I'm gonna try and locate one new for cheap using the Bosch number I found in the archives to cross ref. But PM me your price for the motor or the blower complete, I'm on a budget but interested. I'll let you know either way what I decide to do. Thanks- BG
'84 Carrera Coupe |
Senior Member
BG,
Its just a 15 amp fuse inline to the fan motor. The real Porsche upgrade harness & fuse costs around $20 and is a 1 minute operation. You can do this (I did) or make one up but its well worth having the fuse. Hate to see something burn over this! JoeA
I bought a replacement motor from our host a couple of years back. Part No. 0130007081.
Bill M 88 Carrera 86 944 SP1 06 Cayman SPC |
