Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Placement for CHT guage?
Has anyone modified their oil level guage (that nobody seems to use) to serve as either a CHT guage or a voltmeter? I would think that either would be much more useful than the oil level guage. I'm just consitering places to put a CHT guage and this seems to be the best for at least a stock look in an early 911.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 12-22-2003, 06:07 AM
I use my oil level gauge every time I drive the car. I replaced the clock that I never looked at with a CHT gauge.
-Rob
1980sc
Old 12-22-2003, 08:08 AM
Tim Walsh's Avatar
Rob,
I consitered that but since my clock actually works and this isn't a racecar (a sunny day driver) I'd like to keep my clock.
Tim
1973 911T
2005 VW GTI
Old 12-22-2003, 08:29 AM
banjomike's Avatar
whoa! your clock works!?! Lucky B@&t@rd! Truth be told, mine works to, it keeps perfect time... in some alternate universe.
forgive my ignorance but,
What is CHT?
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 12-22-2003, 08:35 AM
Automotive Monomaniac
Emission's Avatar
Originally posted by banjomike
What is CHT?
I'm just as ignorant.
What is it?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 12-22-2003, 08:37 AM
Tim Walsh's Avatar
A CHT is a cylinder head temperature guage. After killing my old truck by over heating and my 911 by overheating I'm pretty paranoid about loosing my fan belt.
Tim
1973 911T
2005 VW GTI
Old 12-22-2003, 08:39 AM
Emission's Avatar
OK, that makes sense.
Can someone tell us how much they cost, and where do you mount the sensor? I'd (most likely) put an auxillary gauge in my car (and include a few other gauges) instead of replacing the oil level...
Old 12-22-2003, 08:47 AM
I saw a dual CHT gauge on westach.com
They make gauges for aircraft and have a lot of combination gauges.
I have their A/F meter that was resold by CB Performance.
You could use the Oil level gauge if you can get a sender to match the gauge. You could probably repaint the scale on the face.
The gauge should just be an Ohm meter it reads the variable resistance.
I learned a technique off the VDO site to check the resistance limits of the gauge. I did it for my oil pressure gauge. (I am planning to use the oil pressure gauge temporarily to watch my fuel Control Pressure for testing.) I found a universal sender that matched the scale and Ohm range for the gauge.
I'm pretty sure it works the same for the tempature gauge A varible resistor.
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 12-22-2003, 09:08 AM
Tim Walsh's Avatar
I believe most people put them on the intake studs and they cost between $80-$100. Pelican has them along with that "shiny" catalog.
Tim
1973 911T
2005 VW GTI
How about just a big light?
I've seen that somewhere.
Bill Miller
81 Targa Guards Red
Old 12-22-2003, 09:15 AM
Cool
I had this mounted on the console. It is a gauge that I had to monitor constantly in mountain areas, or comming into lala land on I-5 from the north hills in 5th at 65mph, or above 4k rpm in desert heat in 5th gear, etc.
Otherwise not necessary for routine low end street driving.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-22-2003, 09:18 AM
