Weaver's Avatar
The use of trickle chargers
This post will mean very little to the fortunate (or unfortunate) ones who live in relatively warm climates and get to drive their 911s all year long.
Who here is using a trickle charger on their hibernating 911 right now? Has anyone run into problems charging their batteries over these long, cold months? Since my 911 is on jack stands until late Feb., I thought I would try to keep the battery in somewhat usable condition. I purchased a Schumacher 1.5v charger, so atleast it is of good quaility.
So is this a good idea?
Thanks for your time.
Weaver
Weaver
'88 911 Targa
'03 911 Turbo, X73 Susp.
'13 Panamera GTS
PCA member Central Indiana
Old 12-27-2003, 11:09 AM
scottb's Avatar
I live in sunny So. Cal., and sometimes don't drive my car for extended periods of time. I have the Schumacher charger, and it works great.
1984 Targa
Old 12-27-2003, 11:21 AM
Cool
I use a marine style battery lug that has a wing nut to quickly remove/replace the battery ground strap.. the new strap has a hole at the end to fit over the new lug pin..
otherwise I'd disconnect the battery and give it a quick recharge every month or two or six
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-27-2003, 12:17 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
I have been trying to store my car for the winter. Unfortunately, I can't stand to look at it sitting in the garage under it's cover. Since we've had a few days of sun here in Indy, I have gotten it out and tried to steer clear of the salt. I will be stopping in one of those do-it-yourself carwashes to rinse out the wheelwells and underbody at the end of the weekend.
Anyway, my dad lets his sit for up to three months at a time and doesn't use a trickle charger. We have never had a problem with it starting right up. I have heard of units called battery minders that are supposed to do a great job of keeping the battery topped up but not over charging it.
1981 SC ROW Coupe
Old 12-27-2003, 12:27 PM
Original Owner
tsuter's Avatar
I drive mine year round at least twice per month all winter and its ALWAYS plugged into the battery minder when in the garage - even in the summer.
My last battery was a Delco Freedom 60 installed April 2, 1994!
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 12-27-2003, 12:59 PM
I've heard that older straight trickle chargers can overdo a battery, although I have not met anyone who complained of this happening to them. I use a "Battery Tender" which monitors the battery and applies a trickle charge only when necessary. Like tsuter above I've gotten above average life from bike and car batteries. I think it's more important on the tiny motorcycle batteries, which do not tolerate very under/over conditions well.
It's also good not to ask your alternater to bring a battery back from the brink.
Ken
1986 930 2016 R1200RS
Old 12-27-2003, 02:36 PM
absolutely
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-27-2003, 04:46 PM
Adman's Avatar
Send a message via AIM to Adman
Die Hard Battery Tender Plus User
I have used many brands of trickle chargers and about 8 yrs ago comitted to one brand. I use the Battery Tender Plus on 2 jetski, 1 boat and the Porsche. I have gone 6 months at a time without using the water toys and the batteries are always ready to go. All three watercraft batteries are over 5 years old and other than topping off the water once a year they require no maintenance. My buddies at the lake replace their batteries almost annually due to over cooking on trickle chargers or from not charging at all.
Here is a site that explains some of the differences in trickle chargers. They are not all created equal http://batterytender.com
Matthew D.
'87 Carrera Coupe
Guards Red/Cold A/C
PCA Member
Old 12-27-2003, 05:04 PM
