kevs911
Guest
Posts: n/a
I cant find out which tube rubber this is.
I have a 86 911 carrera with the 3.2L engine and this rubber is cracked but i havent been able to find out what its called or who has a replacment. I would appreciate some help. Here is the picture of it.
Old 12-26-2003, 06:24 PM
3.2 CAB's Avatar
That is a major vacuum line for the engine, if you look you will see the "y' connector that then branches off to various vacuum operated gizmos, fuel pressure reg.,fuel damper, cruise, and the like. I do not know why, the used the hyd. crimp on type connector on that hose When I had to remove my fuel rail on that side to r/r the inj. o-rings, I noticed mine had some cracking where the "y' fitting plugged into it, so bad that it would barely stay on, I put a small hose clamp on it, no leaks, and it stays put now. My parts book does not show a # for it, does not really show the metal line with the little bit of hose, just all the other things that plug into it.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-26-2003, 10:19 PM
