avendlerdp's Avatar
Dual megaphone questions...
Hello everyone-
In order to celebrate learning how to use my new TIG welder I am considering making a better exhaust for my 2.2T. It's stock with Webers and SSI's. I plan on setting the car up for some track use and would like to make a set of megaphone style exausts using Supertrapp tips. This seems straight forward enough but I was wondering if there is an advantage to connecting the two sides with an "H" pipe?
Part of doing this is for better looks and a more fun sound but the main reason of course, is to make more power. I know that some later cars benifit much from better exhausts but can there be much gained from a stock 2.2T mill by replacing the stock bananna muffler???
Thanks for reading.
Alex
Old 12-27-2003, 12:43 PM
An H pipe is not needed and in fact reduces power( Check out the GT3 R series cars) When each cylinder bank is isolated, it reduces cross talk between the banks.
This is the solution I came up with using Coast Fab. mufflers. I hope this helps.
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 12-27-2003, 01:20 PM
avendlerdp's Avatar
Basicaly what I had in mind. Not sure I could fab such a nice center bracket!! The next issue is weather this will help much on my stock 2.2t. Thanks.
Alex
1972 Porsche 914 Project
2000 BMW M5
1973 Aermacchi 350
Old 12-27-2003, 01:32 PM
Alex, You will definitely see power gains but it will depend on what else you have done to the engine too. I would recommend using the Coast fabrication mufflers over a megaphone/Supetrapp setup since they are easier to set up. I have attached a link to their website.
http://www.coastfab.com
Cheers, James
Ayrton Senna
1993 964 RS
Old 12-27-2003, 01:41 PM
Stay away from my Member
campbellcj's Avatar
Even compared to a 2-in/2-out sport muffler, I notice a significant gain in top-end power and "revability" with the open pipes. The 6000-7200rpm pull is much better. But, the bottom end suffers at least as much, so you need to keep it over 4000rpm's or you're screwed.
The sound of an uncorked 911 engine at full steam is unequalled. I HIGHLY recommend that everyone experience it some time...
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 12-27-2003, 03:53 PM
Moses's Avatar
Re: Dual megaphone questions...
Originally posted by avendlerdp
...I was wondering if there is an advantage to connecting the two sides with an "H" pipe?
Alex
Only on Japanese cars.
Old 12-27-2003, 04:30 PM
ttweed's Avatar
Re: Re: Dual megaphone questions...
Actually, the big V8 iron in NASCAR uses crossover pipes combined with anti-reversion headers to help the carbs work better, I believe.
I would not recommend putting Supertraps on the end of a set of megaphones unless you have to meet sound regs. Why restrict the open pipes at all if it is for track work? Let the engine breathe. Remember to richen the mixture.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 12-28-2003, 06:35 AM
Moses's Avatar
Re: Re: Re: Dual megaphone questions...
Well, you can use the "H" pipe or the "Y" pipe. How bout the "O" pipe?
Old 12-28-2003, 07:18 AM
304065's Avatar
Megaphones won't help unless you have a motor hotter than a stock "T". You will probably lose torque due to decreased back pressure-- the early cars need a little. The best setup is your SSIs with a dual-in, dual out sport muffler- made from an original factory muffler that's been cut open and modified. Good project for your welder!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 12-28-2003, 07:44 AM
avendlerdp's Avatar
Thanks for the tips gents. I am interested in doing the dual out mod to my factory muffler for street use. I am sure there is a "how to" on the web someplace. Please point me to it and I'll take it from there!!!
Alex
2000 BMW M5
1973 Aermacchi 350
Old 12-28-2003, 08:18 AM
ttweed's Avatar
Yah, sure- that was in this thread
TT
Tom Tweed
R Gruppe #232
Old 12-28-2003, 11:18 AM
jluetjen's Avatar
I'm not sure if a blanket statement that an H-pipe is not useful. Exhaust tuning is a complex subject involving accustics. There is apparently an H-Pipe option for Phase-9 mufflers (called a cross chamber) that helps the system to get below 100 decibals. I doubt that it would be there if there was a better way to get that quite and still make the same HP.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 12-28-2003, 01:51 PM
avendlerdp's Avatar
This is what I thought. I know that on a lot of other cars the "H" pipe is a great way to get the most out of a dual system. I am thinking of making up a system with one just to experiment.
Alex
2000 BMW M5
1973 Aermacchi 350
Old 12-28-2003, 06:13 PM
jluetjen's Avatar
Please be sure to post the results.
John
'69 911E
Old 12-29-2003, 03:13 AM
TerryBPP's Avatar
I made a similar setup using Dynomax Race Bullet mufflers. Let me caution you that they are LOUD!
Old 12-29-2003, 04:53 AM
