3.6 RPM surge on startup
When I start the car, the rpm's will often shoot up to 3k and drop back to idle very quickly. Doesn't do it all the time, and sometimes not all the way to 3k. Will do it even with the engine warm. Any ideas?
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! Last edited by Mike Feinstein; 12-30-2003 at 02:37 PM.. |
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! |
SCWDP- Shock and Awe Dept
Mine does it a bit. I think its b/c of the lightweight flywheel. The stock flywheel was heavy.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
Check the idle solinoid on the right (passanger) side of the throttle assembly. Maybe it is sticking. I would think it is something in the fuel delivery system. Does the fluctuation only occur when idleing or when yyou touch the throttle? If the latter, check the throttle linkage to be sure it is not sticking. Also check the throttle return spring to make sure it is in good condition and clear of the throttle assembly.
Hope this helps.
Paul,
It happens when I first start the car...without even touching the throttle. Throttle action seems fine. Mostly concerned about it hitting 3k when starting from stone cold.
OMG! It's Paul! I was going to give a call, where have you been?
Ryan if you have the throttle cable to tight this will happen, my car did the same thing and i loosen the cable, it still does it a little, Kevin
