Go Speedracer, go!
Question about the Grainger Heater blower motor fix
For those who have replaced their engine compartment blower motor with the Grainger one. I just did this. The motor just doesn't put out much air at all. I'm wondering if I got a dud motor. The previous owner of my car had back-dated the heat on both sides. I re-installed the blower motor and duct work for the drivers side only. I left the back dated heat in tact on the passenger side. I figured this would give me good heat on the drivers side while idling at a stop light and good heat on both sides when the revs are up. When the motor is running while the car is idling, I can barley feel any heat comming from the vent on the drivers side. Does this sound right?
Got most of my information from this post: 911SC heater blower motor
1981 SC ROW Coupe Last edited by SpeedracerIndy; 12-31-2003 at 02:10 PM.. |
I don't notice "strong" heat with a working factory blower, factory heat on both sides, and footwell blowers that work (at least on position 2). Once i get to where I can run it hard up to 4500 or so for a stretch, it gets toasty in the cabin, and the blower keeps up, but it doesn't make my cold car "warm", just tolerable.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
The factory blower in my 82sc puts out quite a bit of heat, compare with my previous 74 with the older non blower heater system.
I did the same Grainger motor conversion a few months ago and got the same results. Not much improvement in air flow. Of course, my factory motor has been dead since I bought the car over 7 years ago, so I don't know if the factory motor spins at higher RPM's or not. I'm guessing the Carerra kick-panel blowers would work better, but as I said, it's only a guess.
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
Go Speedracer, go!
OK, thanks for the replies. It gets the job done even though it's not blasting air on me. I am just used to my fathers Carrera. Those footwell blowers really do a good job.
1981 SC ROW Coupe |
