69 911 2.0E crank specs?
I have a 69 911 2.0E crank that I am selling to someone, and I am trying to find the specks of it std/std. I have a micrometer but I dont know what the factory speck for it. Anyone have this number handy?
Thanks Andrew
"It'll fit?" See my V8 thread Pics of my car Hear it with Magnaflow mufflers and shorty headers Or just hear it with open headers ![]() Hear it current, No ugly tips. louder Incar ax vid. 4-2-05 7-16-05 SCCA auto x Stockton. <---------New! |
S=shaft b=bore
Crank shaft to main bearing main bearings 1-7 B 57.020-57.059, S 56.971-56.990 carankshaft to main bearing Main bearing 8 B 31.041-31.084 S 30.980-30.993 crank pin to connecting rod bearing B 57.020-57.059 S 56.971-56.990 crankshaft to timing gear B 41.975-42.000 S 42.002-42.013 crank shaft to distributor drive gear B 41.975-42.000 S 42.002-42.013 crankshaft to flywheel B 30.000-30.033 S 29.960-29.993 in mm Jim
Jim Hamilton If everything seems under control, your not going fast enough. |
Thanks! Thats just what I needed!
Andrew
Dad speaking....
So if I understand this correct. The rod journals translate to this: If they were standard they would be within this tolerance. rod journals standar tolerance 56.971 mm = 2.246574 inches to 56.990 mm = 2.245406 inches If they were undersized by .010 then take off the following from the .2539 mm = .01000 inches 56.7171 to 56.7361 mm or 2.236574 to 2.235406 inches mains 30.980 mm = 1.220612 inches to 30.993 mm = 1.2211241999 inches
