Quick fuel injection question
I have been having performance problems on my 77 2.7. After posting some questions here (thanks for the responses), I have checked several things and have run across what may be my problem with lack of power. After removing my A/C (don't worry there was no ozone depleting substances delivered ito the atmosphere), I noticed that the injection line right behind the A/C unit was cracked (this explained my gas smell after the last test drive). When I went to check it, it basically snapped in half. Now after reading and searching tech articles, I want to be sure that this one is the number 4 cylinder (first cylinder on right looking from the rear of the car). I also want some feedback on places to buy these lines. Pelican has the 4,5,6 lines but do not list 1,2,3. I thought about replacing them all. Any good places to buy them as a set or at least 1,2,3s? Thanks in advance!!!
Dean
Old 01-01-2004, 03:00 PM
Jim Smolka's Avatar
Yes, the 4th cyl is on the passenger side closest to the bumper.
Also a good idea to replace the o-rings and sometimes the sockets that the FI plugs into.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 01-01-2004, 03:25 PM
Jim,
Is there an easy way to test the FI themselves? Or clean them?
Dean
Old 01-01-2004, 03:32 PM
retired, mostly
sammyg2's Avatar
Call pelican anytime you don't find something on the website. They have it or can get it.
Old 01-01-2004, 03:59 PM
Jim Smolka's Avatar
There are several ways to check that a FI is OK.
A simple way is to remove the FI from one side. Compare the spray patterns as the big disk is moved. The spray should be about the same. Usually, the difference is seen when simulating a light throttle input. If the pattern is not the same, remove the suspect injector with one that is good as sometimes the FI is good, but the fuel distributor is clogged/and or shot.
At the risk of having the SCWDP hunt me down, it is also possible to replace the CIS FI system with a DME FI from a Carrera.
'81 SC 3.6 (Beast)
Old 01-01-2004, 04:07 PM
