-   -   Bilstein struts & rear dampers (http://forums.pelicanparts.com/porsche-911-technical-forum/142099-bilstein-struts-rear-dampers.html)
andyjboy 01-02-2004 05:25 AM
Looking for clarification here - there are a number of different Porsche part numbers listed for front Bilstein struts used on 911's from 1971:
911 341 943/4 00 ('71-'72)
911 341 041/2 33 ('73)
911 341 079/80 36 ('74-'76)
911 341 041/2 30 ('74-'76) 'Sport' ?
911 341 041/2 31 ('77-)
What are the differences between these struts ?
Are they interchangeable ?
My '69E (originally fitted with hydropneumatic front struts) currently has Koni front struts (with alloy 'S' calipers) & rear shockers - would there be any (significant) advantage in swapping to Bilsteins ?
I know that the rear suspension was modified at some point (1972/3?) to alter the angle of the shocks & again around '76 (?) when I think the lower mount was changed to a smaller size.
Does anyone know if all pre-'76 rear shocks will fit my '69 model or are there differences ?
Andy
'69 911E------>R
