Ground question
I was wondering if I could put a ground strap from the intake manifold to one of the bolts that hold the plate that holds the CDI unit to the body of the car. I currently have a ground going from the tranny to the ground post but it doesn't always get the ground to start. I believe the tranny ground connection needs to be cleaned which I have tried but to no prevail. I can't really get my fingers in place for a good cleaning and will wait until next time I drop motor. Any suggestions about the CDI plate.
Thanks,
Old 01-03-2004, 07:10 AM
Senior Member
Early_S_Man's Avatar
Porsche Crest
Argeo,
I ran a braided ground strap about 8" - 12" long from under the upper, forward CDI mounting bolt arond to the round, fender ground for the relay/fuse/CDI panel ... after cleaning that fender ground location with ZUD. Dow Corning silicone grease at both ends of the strap, and all over both mounting bolts/nuts.
Then, I ran a #4 ga. welding cable with soldered lugs from the body to the lower mounting stud of the starter!
There is already a factory grounded shield braid from the distributor and coil to the CDI/relay panel ... which may need cleaning and treating with silicone grease.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-03-2004, 07:23 AM
