North Coast Cab's Avatar
Engine In - Won't Start
Finally got around to putting my engine back in and it won't start. While out I did basic oil leak work, installed new plugs, ignition wires, and Steve W chip. Rechecked the firing order and everything seems fine. Is there a common area to start looking in? All electrical connections seem back in place.
John
1985.5 944 GTS
Old 02-14-2004, 11:37 AM
No spark.
1985.5 944 GTS
Old 02-14-2004, 12:11 PM
carmaneddy's Avatar
Make certain you connected the bg and dg sensors correctly
follow this thread: <Note on 3.2L Motronic Reference Sensor>
Old 02-14-2004, 12:47 PM
No power to the coil.
1985.5 944 GTS
Old 02-14-2004, 12:48 PM
carmaneddy's Avatar
check your 14 pin connectors for wear. I had to rewire one of mine.
Old 02-14-2004, 12:51 PM
Irrationally exuberant
ChrisBennet's Avatar
If you remove the reference&speed sensor bracket and forget to reset the sensor to tooth distance to 0.8mm the car won't start. Don't ask me how I know this...
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-14-2004, 01:07 PM
She's running. A few of the electrical connectors weren't seated correctly. You know the ones, they have that stupied square metal locking clip. Thanks, for the help.
JOhn
1985.5 944 GTS
Old 02-14-2004, 01:25 PM
carmaneddy's Avatar
which ones?
Old 02-14-2004, 01:31 PM
