911 wont start
My car is currently stuck in a gym parking lot. It started fine, drove 5 minutes to the gym, worked out for maybe 25 minutes, came back out and the car wouldnt start. It cranks over fine, but there is no ignition. It is acting like a car without gas, and there is no smell of gas as I try to start.
There is a 3/4 tank of gas and the battery is fine.
Help!?
-Matt
ps: outside temperature is in the 50's, 60's, car did not drive through any puddles, car has never done this before.
Old 01-04-2004, 07:21 AM
Assuming you have a CIS car, do you hear the whine of the cd box when ign is on?
You should also hear the fuel pump with ign on, you may take off the air box cover and lift the plenum you should hear fuel pulsing to the injectors.
Old 01-04-2004, 07:45 AM
davis911s's Avatar
What year is the car? If it is a CIS like mine you may be having the "warm start" problems many of us have had. It is an easy fix with either a new check valve or accumulator. But it could be something else to. Where it sat for 25 minutes I think it might be something else because if mine would NOT start and I let it sit for 1/2 hour thats when it would start
IF CIS - open the airbox, take out the air filter, there is a lever on the inside top of the airbox push it up and let it come down under its own power, do this 2 or 3 times then try restarting it
Let us know more about the car, year, engine etc
Shawn
Shawn
77 Targa with 2.7
My never-ending work in progress that has been off the road since Mar 2004
Old 01-04-2004, 07:57 AM
it is an 86 911 Coupe. That would be the mfi, not CIS i believe.
-Matt
Old 01-04-2004, 08:50 AM
Lorenfb's Avatar
Check out this website (www.systemsc.com) on the Diagnostics page
under No-Start for some possible helpful info.
The most common 3.2 problems are:
1. DME relay under drivers seat
2. bad electrical connections
3. bad pickup sensors
Good Luck
Loren
'88 3.2
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 01-04-2004, 09:27 AM
I wonder if this has anything to do with the use of Redline Fuel Injector Cleaner I put in 2 days ago for the first time as I filled it up.
-Matt
Old 01-04-2004, 10:01 AM
Send a message via ICQ to old_skul
Not likely. I would start with the DME relay under the driver's seat. There is a particular line in the circuit which *always* fractures and the car won't start.
Sometimes pulling it out and putting it back in works. Also check your distributor cap; make sure it's on firmly. Check your coil wire. Then grab a spare spark plug, pull a wire out, and hook it up. Have an assistant crank the engine while watching the plug for spark. If you have spark, then it's a fuel problem; possibly a bad fuel pump, fuel pump relay, or DME relay (or DME unit).
Good luck.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 01-04-2004, 10:31 AM
Langers's Avatar
-Matt
'86s run on Motronic (DME), not MFI.
2004 VW R32 - B road bahnstormer
1992 Peugeot 205 - Tarmac rally weapon (well eventually...)
Old 01-04-2004, 02:30 PM
3.2 CAB's Avatar
Hi Matt, can you hear the fuel pump running? Either when you turn the key to the run or start position? If you hear the pump going, then at least half of your DME relay is working. Do you have spark, if not, could be as simple as the other half of the DME relay bad. If you can, try a known good relay, if it still does not start, it is likely that the Ref. mark/speed sensors have taken a dirt nap.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-04-2004, 09:18 PM
right, i was thinking mfi as in motronic fuel injection...
Old 01-04-2004, 10:09 PM
