Here's a good one . . . (electrical problem)
Occaisionally my radio will die while I am driving my '73S if I turn on the headlights, turn signal, or even brake lights. If I stop and restart the car after a rest, all works well, but I have to push or jump start the car because the battery is drained.
The problem may be related to the state of battery charge when I start the car the first time. The last two times the problem has surfaced were 1) after I had the interior light on for a while and drained the battery while replacing door seals and 2) after the glove box light was inadvertantly left on over night.
Any ideas about whether something (batteries, regulator, etc.) is going bad, or is this normal for a low or drained battery?
Old 01-05-2004, 09:47 AM
vash's Avatar
starting batteries are not good at recovering after being totally discharged. i think you need to get your battery tested, maybe replaced and then see if any of the other issues are still around.
poof! gone
Old 01-05-2004, 09:55 AM
Larry Harris's Avatar
Jay,
Used to have the same problem on an old Corvette. You might consider a "trickle" type battery charger. 2 amps worked fine for me. Bought it several years ago and it still works great. Unfixed is right-a bad battery isn't going to respond to charging.
Regards
Larry
2001 Turbo
Old 01-05-2004, 10:02 AM
304065's Avatar
You don't say what kind of a radio you have but I'm assuming it's a modern solid-state one-- if the voltage drops below a specific level (probably around nine volts) the unit is probably shutting itself off. This coupled with the fact that the starter won't crank after a shutdown episode signals a classic low-voltage problem.
Do you still have the dual battery setup? What type and how old?
Your alternator really isn't intended to bring the battery(s) back from a discharged state. When they are really low, the alternator will overheat trying to bring them back. If your batteries are only a year or two old, I would take them out of the car and charge them for a couple days using a battery charger on the 2A setting. You might also give them a test using a "load tester" which will actually put all the current through a heating element (looks/smells like an electric toaster) and allow you to measure the battery's strength. Your FLAPS may have such a tester available.
Anyway, once the batteries are topped up to 12V, you are then ready to test the charging system. When you turn the ignition "on" what does the idiot light do? It should glow brightly. When you start the car and rev the engine past about 1000 rpm the idiot light should go all the way dark. If there's ANY deviation from those results, e.g., no idiot light on with key on, or a dimly glowing light at idle rpms, this is indicative of a fault with the charging system.
Last, with the engine running, measure the voltage at the battery terminals with a voltmeter. It should read around 13.5-13.8 volts. The alternator puts out 14V when it is working properly, but there's a voltage drop going from the alternator to the starter post up the big wire and to the batteries. If it reads less than that, or reads the same whether the engine is on or off, there's your problem.
Do NOT disconnect the batteries with the engine running as this will result in the immediate destruction of the alternator.
Good luck!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-05-2004, 10:07 AM
Thanks, all. I do have still have the 2 battery set up, and I'm not sure how old they are. The radio is a modern Sony.
It's snowing here in Portland today, which means that the city is entirely shut down, and I have a chance to hook the batteries up to the trickle charger. I also stopped by my FLAPS yesterday and had them test the charging system--all looks good, so I am assuming that the problem is battery-related.
'73 CIS T with a 3.2 on a stand in the corner
Old 01-06-2004, 12:56 PM
