Transmission Dimensions
I am considering a project and would like to know the following measurements:
1.) the distance from the center of the axle to the end of the bell housing for: a.) 901 Trans. b.) 915 Trans. (thru '77) c.) 915 Trans. ('78-'83) d.) 993 Trans. ('96-'98) Thanks, John. Last edited by 911split; 12-28-2003 at 12:55 AM.. |
Pretty please? Someone? Anyone?
Hi John;
I can get you the information for a 901/911 gear box(s) later this week since I have one of each. - John
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Could you do a sketch so we understand exactly which dimension you are looking for?
Thank you for your time, |
On the 911 box that I have in my garage, it was about 8 1/4 inches from face where the bell housing mates to the engine, and the center of the bolt in the middle of the axle flange.
Thanks for the replies. I'm going to see if i can somehow post a sketch that will help to clarify the measurements that i need. Maybe Jan. 1 or else Jan. 4
Here are the sketches...
I am considering a special project and need the following measurements (note: accuracy is of utmost importance! If possible, measurements in (mm) preferred due to increased precision):
1.) Distance from the center of the transmission side cover to the end of the bell housing for: a.) 901 Trans. ('65-'68) 5-speed, aluminum b.) 915 Trans. ('72- '77) 5-speed, magnesium c.) 915 Trans. ('78-'83) 5-speed, aluminum(?) d.) RUF Trans. (early) 5-speed, (has short bell housing - see 911 Performance Handbook, p.202 edition 1 or p.231 edition 2) e.) 993 Trans. ('96-'98) 6-speed 2.) Distance from where the engine bolts up to the bell housing to the front of the fan housing for: a.) 911 2.0L ('65-'67) aluminum case b.) 911 2.0, 2.2, or 2.4L ('68-'73) magnesium case c.) 911 3.0L ('78-'83) aluminum case d.) 993 3.6L ('96-'98) ![]() 3.) Distance from center of rear wheel to the end of the fan housing for: a.) 911 ('65-'68) - short wheelbase (2211 mm / 87.1 in.) b.) 911 ('68-'71) - long wheelbase (2268 mm / 89.3 in.) c.) 911 ('72-'74) - longer wheelbase (2271 mm / 89.4 in.) d.) 911SC ('78-'83) - wheelbase (2271 mm / 89.4 in.) e.) 993 ('96-'98) - wheelbase (2272 mm / 89.4 in.) f.) 911 with early RUF 5-spd. (please state engine it's paired with) (Wheelbase clarification needed: i have seen countless conflicting wheelbase specifications for SC's, 964's, and 993's...does anybody have the true authoritative factory-backed specifications?) Your help will be greatly appreciated. Thank you. Last edited by 911split; 01-05-2004 at 04:53 AM.. |
As deputy Cartman said in Chicken Lover episode: Respect my authoritaa!
This is for 930's post -77: This is for SC's and early pre -78 930's:
what are you going to do? maybe a 911 engine in a split bus?
