transmission noise?
I have a 1973 2.4S MFI.
on a couple of occasions I have heard a funny noise from my transmission (915) It has always happened when I have accl up through the gears to about 200kph+ (on a private test track of course) then let off until about 100 - 120 kph & cruise. I get a real coffee grinder kind of rumble. If I cruise carefully for a bit & give it throttle a couple of times the noise goes away. This has only happened 3 times & it was all on the same journey when I 1st got the car. Have not heard since but then again I have not had the use of a private test track I don't think it could be the tyres even tho one of the rears needs changing. any ideas? BTW I have not checked the gearbox oil
1973 2.4S 1993 964 C2 |
It might be the CVs. Much cheaper.
Maybe change the gearbox oil for some Swepco 201 and grease the CVs. And welcome to the bullitin board. |
