Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
915 speedo sender
The speedo sender wire was cut short when I got the 915 with my 3.0 last year.
Question is, what is the thing in the blue circle? A gasket, or something else? I can replace the plug, but not if something else is missing.
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 01-06-2004, 01:06 PM
addictionMS's Avatar
rubber bellows to seal the outside out as the wire passes into the chassis
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 01-06-2004, 01:36 PM
TedSlick's Avatar
That I would think is the rubber boot the sender wires pass thru transitioning from the exterior underbody to the interior (tunnel). The boot will probably already be present on the car you're installing into. Check it out.
Old 01-06-2004, 01:39 PM
TedSlick's Avatar
addiction answered before me
anyway, I took lots of pics during a past engine drop. here are a couple showing the wires on each side (int/ext)
Old 01-06-2004, 01:53 PM
Stahlwerks.com
jhelgesen's Avatar
As my son would say, "YOU GUYS ROCK"
Thanks for the info and the pics.
John Helgesen
Old 01-06-2004, 01:58 PM
