magic930's Avatar
Clean Heat Exchangers!
Got snowed in today in Seattle so I took the opportunity to clean my heat exchangers! These are aluminum exchangers from a 930; A before vs after cleaning photo is shown below.
Old 01-06-2004, 04:04 PM
No Expert
jgparker's Avatar
What did you use? I always assumed you could never get the shine back on the pipes.
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 01-06-2004, 04:24 PM
TedSlick's Avatar
Yes, how did you do it...some sort of (wire) brush? On mine I can see the shiny below the surface layer, but the surface layer looks like some kind of coating and I was concerned about removing it.
Old 01-06-2004, 07:12 PM
Doug E's Avatar
Nice job.
I recently wire-brushed mine down to (mostly) bare metal and shot them with some high temp aluminum colored paint. Finish isn't a shiny as that above but it will pass when the car is on the lift
Doug
'81 SC Coupe
Old 01-06-2004, 07:28 PM
magic930's Avatar
First I cleaned the whole thing with "Gunk" to remove as much of the oil and baked on oil as possible, scrubbing hard with a tooth brush and a small brass wire brush and letting it soak overnight. I had a lot of oil leaks which had crusted up on the surface (especailly the top side not shown in the photo) .
The lower exchanger in the photo is after cleaning with the Gunk.
Using a "medium coarse" wheel type wire brush on an electric drill followed by a "fine" cup type wire brush took all the stains and corrosion away and polished the surface. I will probably do another pass with a polishing compound on the bottom side to make it shine some more.
Old 01-06-2004, 07:46 PM
al lkosmal's Avatar
looks nice. a snow day. I was going to install my new CV's, but too chilly in the garage or at least that's my excuse. Nice work. Did you get much Snow???
RGruppe #669
http://www.x-faktory.com/
Old 01-06-2004, 09:45 PM
Re: the first post....
I don't think this is correct. The factory heat exchangers are a low-grade ( from a *cosmetic* standpoint), rust-resistant stainless steel...not aluminum. I polished mine up the same way ( on my NA 3.2 Carrera) using a wire wheel....
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-07-2004, 09:20 AM
I just did this, bead plasted it clean and then used "Rub N Buff" on it. Rub N Buff is a trick I learned a while ago on engine components. Works great, easy to apply, and with last a long time on exhaust parts.
Porsche 2005 GT3, 2006 997S
Exotic: Ferrari F348TB Factory Challenge, Ferrari 328 GTS
Disposable Car: BMW 530xiT, Audi A3S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-07-2004, 10:07 AM
