Britain Smith's Avatar
Emergency Brake
Can someone shed some light on how to remove the emergency brake from the rear hub? I messed with it for a bit last night but I couldn't figure it out and I don't know where my book went.
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 01-08-2004, 09:59 AM
There is no one here that can help me out on this?
-Britain
Old 01-08-2004, 11:01 AM
vash's Avatar
the smart guys are probably working...
you'll get help soon.
poof! gone
Old 01-08-2004, 11:12 AM
There has to be someone here who can chim in on this one...
Old 01-08-2004, 05:34 PM
JWest's Avatar
You didn't like the answer at "the club"?
James
JWest Engineering
Old 01-08-2004, 06:20 PM
Zeke's Avatar
Four bolts. Same four that hold the bearing retainer on the arm. The ebrake backing plate will be stuck to the arm, knock it off with a rubber hammer.
Old 01-08-2004, 06:23 PM
JWest's Avatar
Milt, he wants to remove the cable (hard to figure that out from the question).
Remove the caliper, remove the brake disc, and then you can get to the cotter pin and nut on the end of the cable.
James
JWest Engineering
Old 01-08-2004, 06:34 PM
Zeke's Avatar
Coulda fooled me..........
He'll have fun at the other end, hah!
Old 01-08-2004, 10:16 PM
Early_S_Man's Avatar
Porsche Crest
If much rust is present ... getting off the rear rotors can be a real pain! There are two countersunk slotted M6 screws that can probably only be removed by using a very tight, precise-fitting drive bit on a 'hammer' type impact driver usually sold at motorcycle shops!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-08-2004, 11:08 PM
