Now in 993 land ...
aigel's Avatar
What happens if you disconnect O2 sensor (CIS)
81 SC. Fiddling with the wiring on the left side of the car. Yikes, the 02 sensor connector that bolts to the chassis is disintegrated and the connection fell off!
I passed smog with flying colors last spring. Does this mean the thing fell off since then?
I guess I will have to get a used connector or hack something to re-establish connection. What happens if I drive it with 02 sensor disconnected?
TIA, George
81 SC (sold)
Old 01-09-2004, 07:27 PM
Lorenfb's Avatar
As long as the mixture is not too rich (CO>>2.5 to 3.0% before the CAT),
you should have no problem. The Lambda control unit will seek a neutral value
of .50 volts, and thereby a neutral mixture determined by the mixture adjustment
screw.
Good Luck
Loren
'88 3.2
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 01-09-2004, 08:03 PM
Metal Guru
911nut's Avatar
George, your still messing around with that?
Get an exhaust gas aanlyzer and set the CO to 3-3.5%. When it's time to get tested set to 1% and drive gently to the testing station.
You will pass the test easily. Drive slowly home, reset to 3-3.5%. I know someone in Arizona who does this every year. He doesn't have a cat either.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 01-10-2004, 05:19 AM
Now in 993 land ...
aigel's Avatar
Paul!
It's not by choice man, I found the thing disconnected. Isn't that humorous? I am just wondering if I can hurt anything.
The other thing is, is that connection somehow special? It looks almost like a HV connector. Very strange ...
George
81 SC (sold)
Old 01-10-2004, 10:24 AM
GFCC
Jeff's Avatar
Old question that was never really answered... if setting timing and mixture on an '82 3.0 would you just leave the O2 sensor disconnected and proceed or hook it up?
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 11-12-2006, 02:16 PM
I'm with Bill
Rick V's Avatar
I know a few people who run thier SC's with the sensor unhooked. It will go to a default setting that is a little rich. This is good for making power in our cars. It shouldn't hurt anything. Even with the 02 in line the correction value is only 20%
Old 11-12-2006, 02:20 PM
