OldTee's Avatar
79/80SC Fuel Pump Diff ??
Is there a difference between the 1979 911SC fuel pump and a 1980 911SC? Pelican parts does not show a check valve for the 77-79 Fuel Pump. How does this change the operation of the CIS?
Old Tee
all 911s sold
Old 01-10-2004, 06:09 AM
Heck, I’m only 5 not 71!
targa80's Avatar
I have an 80SC and the fuel pump has an internal check valve. When I was having hot start problems I troubleshot it down to the internal check valve. I ended up putting an external check valve on the pump to Fix the hot start problem I was having. If you buy the external valve make sure you also buy the added hardware to adapt to the original banjo fuel line fitting.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 01-10-2004, 07:06 AM
vash's Avatar
new crush washers are a must! at least it was for me.
poof! gone
Old 01-10-2004, 10:02 AM
